Electric Kettle
Jun 11, 2012
1,533
33
19,685
Lynn any caravan accessories shop will sell low wattage kettles .They do take longer to boil
Sir Roger
Mar 10, 2006
3,274
47
Lynn_374353126 said:
Can anyone suggest a low wattage kettle as mine keeps tripping the electric ?.
thank you
Lynn
Yes go to your local caravan shop, buy a 1kw kettle for about £15/20.
Our old one still working was 750 watt and took forever, the 1kw is much quicker.
Aug 28, 2005
1,318
i have used a standard electric kettle for years with no problems , just turn every else off its only for 2-3 mins ,
Jul 15, 2008
3,900
1,085
Lynn....... if like me you also carry a gas hob kettle, then consider one of these (others are available)
Make sure one of the rings is rated at 1000watts which makes it a low power appliance.
They have the advantage of being more versatile than a kettle
If you are paying for an EHU why use gas?
http://goo.gl/5Z3EK
I also use a domestic kettle if the site supply allows.
Most club and large sites have a 3000watt supply and a domestic kettle will be fine as long as you make sure other heavy use appliances are turned off.
When a supply trips off, the kettle often gets the blame, when infact the kettle would be OK if the total electrical usage did not exceed the supply.
They boil quicker if you fill just prior to switch on using water from the hot tap
Dec 14, 2006
3,205
Uurgh! No thanks. We don't ever drink any of the water which comes via the aquaroll, always using fresh water from the site tap or if we're further away from a tap from the fresh water in a 5L bottle which we keep for top ups. We make sure this is newly filled morning and evening.
We've just bought a nice new whistling gas kettle - http://www.goodyears.co.uk/PBSCProduct.asp?ItmID=9452752 - which is very snazzy. It comes in various colours to match your interior!
Mar 21, 2007
443
18
18,685
I bought one recently from Amazon, just look out for something described as a travel kettle or be sure its 1kw or less.They take longer to boil than gas but whats the rush
Quote
"Uurgh! No thanks. We don't ever drink any of the water which comes via the aquaroll, always using fresh water from the site tap or if we're further away from a tap from the fresh water in a 5L bottle which we keep for top ups. We make sure this is newly filled morning and evening."
We have for the past 30 years used the water from the aquaroll via the onboard tank here and in France and Spain etc
We do boil it in the kettle
That's what they do
