Emove em203
Mar 9, 2021
Hi guy's in new to the group I'm looking a bit of advice I bought a secondhand emove motormover when it's powered up 1 of the movers is making a buzzing noise but no movement any advice would be great thanks.
9,148
Is it fitted yet to the caravan? If it is it could be something simple like a poor battery connection wire within the battery terminals. iE not clamped tight in the terminal.
4,359
Your description of "buzzing" concerns me. The system is 12V dc operated and that should mean there is no way any of the components should buzz.
If it isn't the battery connections, and assuming all the other wires have been correctly installed, then it will either be the control board or the motor.
To help identify if the problem is the circuit board or the motor, if you disconnect the wires for motors at the circuit board, and swap the right hand motor over with the left hand one and try again.
If the same motor buzzes then the fault is with the motor, or if the other motor now buzzes, then its the circuit board.
Perhaps it was being sold second hand becasue it was faulty? It might be worth checking with the person who sold it you.
937
From your description it seems like there is a couple of possible things wrong.
It may be broken or worn carbon brushes, or it could be a seized motor or a seized gearbox, or a broken shear pin on the roller.
Whichever it is it is going to have to be removed and stripped down to isolate the actual problem.
Mar 9, 2021
I have a video but for some reason it wont let me upload it
2,592
Is your caravan battery fully charged
