shakeyblade said:
Has the season draws to a close, what are the most impotent we need to do when locking up for the winter?
this is my first caravan, so as much info as possible woul;d be highly greatful
thanks in advance
shakey
I've no doubt that you'll receive replies which encourage you to use your caravan all year round, but if you do store your caravan for any length of time over the colder months there are some things that you really must do to avoid damage from frost.
Completely drain the water system including the water heater. There should be a drain tap usually under one of the front lockers on the water pipe system, or if your caravan uses the older Carver type system there will be a drain plug on the outside of the caravan on the unit. Open all of the taps, including the shower, remove the flexible shower pipe and make sure that all of the water system is completely drained.
Empty the toilet cassette and the toilet header tank and lubricate the toilet seal using Thetford seal lubricant or olive oil (not petroleum jelly).
Keep the leisure battery charged, cold weather kills batteries.
Leave the fridge door ajar to minimise the risk of mould or odour.
Put the sink and shower plugs in to avoid insect infestation.
Remove all traces of food, toilet tissue or kitchen roll, rodents can use these materials to build nests and foodstuffs will attract them.
Remove bedding, pillows and cushions and place the seat upholstery away from the caravan walls.
Fit wheel clamps, locks and alarms and check that your insurance policy is valid.
No doubt there will be more good suggestions but the draining of the water system is essential, so if you do nothing else, do that.
