- Mar 14, 2005
- 18,829
- 4,069
- 50,935
Most heating in the UK is still either burning gas or consuming electricity in resistive heating systems. Whilst gas boilers of up to 40 year sold should be 70% or better at converting gas to usable heat, and electric resistive heating is 100% in both these cases the energy is used to produce heat directly from teh fuel used.
Air conditioning is rather different. The energy consumed is not directly turned into cold, instead its used to draw heat from a hot place and dispose of it remotely.
Basically an AC unit move a lot more heat energy than the energy it consumes to operated it, and that is why AC units are given a COP (Coefficient Of Performance) rating, not a simple efficiency rating.
Just as a heads up, air source and ground source heat pumps use exactly the same principle of the phase change of a fluid to absorb and dissipate heat energy, so their heat energy transfer capability is not exactly related to the energy used to run the system, though in general if you need to move more heat energy you will probably need to consume more energy to drive the system.
All such systems will operate across a wide range of conditions, and as the conditions change the actual COP will vary, so its not necessarily the case it will need twice as much power to operate if the temperature difference between the two sides of the system is doubled, or vice versa. Each appliance should be rated by its manufacture, and hopefully provided with example performance curves for different temperature and humidity conditions.
