Essentially equipment
Jul 2, 2020
Hi guys I have just bought a caravan and was wondering is there a list of essentials I need to buy b4 we head of on our first adventure cheers
5,154
Battery if it has not got one. Aquaroll, wastemaster, EHU lead, drain pipe for waste water. Of course crockery, cutlery, glasses, pots and pans.
8,945
Here’s one from the Caravan and Motorhome Club. If you Google search essential caravan checklist there’s quite a few out there. You can then decide what the essentials are fir your first trip out. And build on it from there on.
271
80
10,735
Before rushing out and buying new have a look on eBay or gumtree for used equipment, particularly caravan step, water and waste hog, hook up leads etc, you’ll save a fortune.
Examine equipment sold in caravan shops carefully, some of it is really poor quality and won’t last the distance.
8,945
Also Caravan Club classifieds have some good gear for sale and you can search by region.
5,154
Good suggestions, but even better is www.preloved.co.uk
2,553
Also look on freeads.co.uk
1,819
If you are going out to a dealer for the basics suggested by Buckman you might ask if they will give you a discount for the bulk buy.
If buying electrical equipment do be aware of the limitations of the power supply on some sites. Most are now 16 amps and will accept most things, but some care is needed. Sopme though may be only 10 amps and you can trip the fuse switch if you are not careful. On that basis avoid the very powerful versions of items, especially the kettle as they cam overload the system. More basic kettles with a lower wattage are the best bet. The other most likely problem item is a hair dryer, but you can use the lower power settings on these if other electrical items are running.
Jul 3, 2020
73
34
85
Gas bottles and Gas bottle spanner...
A piece of kit I didn't realise one needed, well in my defence even though I'd been camping for many years, most of these was in a trailer tend, with a 2 burner and grill, so always used to Blue Colour gas... Didn't realise that you need to ensure that when you've connected the Red 6kg bottles, you need to tighten the connection with a spanner!
2,553
Double caravan waste water outlet hose / pipe adapter
4,486
If you use a shower in the caravan, then a second Aqua roll. , I dont bother with the low wattage kettles, ie, 600/900 watts always take a medium power one 1200watts, just make sure the boss doesnt dry her hair at the same time.
Don't buy light weight plates from Caravan shops , go to Dunelm.
Caravan shops meens £xxxx
Reactions: Tuningdrew
5,154
If you use a shower in the caravan, then a second Aqua roll. , I don't bother with the low wattage kettles, ie, 600/900 watts always take a medium power one 1200watts, just make sure the boss doesnt dry her hair at the same time.
Even better buy Corelle plates. Best on the market and last forever. We have never used a torque wrench. For waste water we use one of these water connectors. No faffing around. We have a low wattage kettle which takes forever to boil, but you are on holiday so what is the rush? :D
Jan 31, 2018
1,783
850
We take a full whack fast domestic kettle. Happy to switch the heat/water off for a few seconds while it boils,same with our dolce gusto coffee machine. Cant be doing with low wattage ones and we've never tripped the box yet. Just work out mentally what you are using v the site amps provided.watts/volts
8,945
IKEA do similar plates, bowls etc to Corelle but much cheaper although only in white. But as said above they are tough as nails and lightweight. So much better than melamine.
1,819
We have both a low wattage kettle and a normal one. We have been on sites mainly in France where we got only six amps and needed a lot of care not to blow the fuse. I have tended to use this on 10 amp sites over here, although are getting pretty rare now.
We have used things from Ikea in the caravan as well and have had no problems. It tends to be lightweight and works although most of our crockery came from Asda.
Feb 23, 2018
916
87
18,935
If you need a gas bottle, do yourself a favour and get a Safefill bottle rather than Calor gas. I got a 'Starter Kit' with my new caravan in 2018 which included all the basics (hadn't needed most stuff before with my old van) and a single 6KG Calor propane bottle - I use very little gas so am still on that original bottle. If I had a Safefill I could top it up for £6. But now I am gambling on running out or wasting a good amount of gas on a £25 refill. Its also much lighter, so will help your payload.
Our old 19p Ikea plates have rattled around in the plate-rack for ~3 years with no issues. Good to have proper plates rather than melamine; they can also be used in the microwave. Also have a normal kettle - an ASDA basic plastic kettle c£5.
I would add that I only tripped the site bollard once: the Fridge was running, Truma heating was on full on electric, all the lights were on and the microwave was running. I then turned on the Kettle and it tripped. Oops.
Feb 23, 2018
916
87
18,935
A piece of kit I didn't realise one needed....
My van has a handwheel for attaching the gas bottle. No spanner needed. I guess you can fit these if/when replacing the gas pipe (by a qualified gas fitter).
Torque wrench - checking caravan wheel nuts - caravan tool
Definitely. 100%. Don't care what anyone says about it being unnecessary. I check the Torque before each tow. I also check my car's wheel bolts too. I've been removing the wheels to improve the appearance of my corroded diamond-cut alloys so need to check them after refitting; and of course for checking after tyres are replaced.
Reactions: JezzerB
