Before rushing out and buying new have a look on eBay or gumtree for used equipment, particularly caravan step, water and waste hog, hook up leads etc, you’ll save a fortune.
Examine equipment sold in caravan shops carefully, some of it is really poor quality and won’t last the distance.
Good suggestions, but even better is www.preloved.co.ukBefore rushing out and buying new have a look on eBay or gumtree for used equipment, particularly caravan step, water and waste hog, hook up leads etc, you’ll save a fortune.
Also look on freeads.co.ukBefore rushing out and buying new have a look on eBay or gumtree for used equipment, particularly caravan step, water and waste hog, hook up leads etc, you’ll save a fortune.
Even better buy Corelle plates. Best on the market and last forever. We have never used a torque wrench. For waste water we use one of these water connectors. No faffing around. We have a low wattage kettle which takes forever to boil, but you are on holiday so what is the rush? 😀If you use a shower in the caravan, then a second Aqua roll. , I don't bother with the low wattage kettles, ie, 600/900 watts always take a medium power one 1200watts, just make sure the boss doesnt dry her hair at the same time.
Don't buy light weight plates from Caravan shops , go to Dunelm.
Caravan shops meens £xxxx
IKEA do similar plates, bowls etc to Corelle but much cheaper although only in white. But as said above they are tough as nails and lightweight. So much better than melamine.Even better buy Corelle plates. Best on the market and last forever. We have never used a torque wrench. For waste water we use one of these water connectors. No faffing around. We have a low wattage kettle which takes forever to boil, but you are on holiday so what is the rush? 😀
Gas bottles and Gas bottle spanner...
A piece of kit I didn't realise one needed....
Torque wrench - checking caravan wheel nuts - caravan tool
