Nigel,
I must take serious issue with the advice on page 91 (used car buyer) & specifically the advice " Take the wheels off at home and coat the mounting surfaces with copper grease" this is the WORST thing that you could do! if you put copper in contact with aluminium (or any aluminium alloy) and then that contact is subjected to any salt water solution (road salt & water mixted) YOU WILL induce SERIOUS corrosion, it's called galvanitic reaction, what will result is the rapid corrosion and deteteriation to the extent that the alloys will disintergrate at the point of contact!
By all means take off the alloys & grease the mounting point (but grease it very spariningly) with any molyblendum type grease, but NEVER copper grease.
The alloys do corrode as you mention and then they corrosion weld to the hubs making it almost impossble to remove an affected wheel at the roadside!
