Fenwicks or Jennychem
On my aluminium bodied caravan I used"blaze" to clean it as directed, followed by autoglym super resin polish,then armour guard wax and finally a coat of Maguire's ceramic
I have both in the garage and they both do the job, but you need to use a large amount of Jennychem in a 10 litre sprayer. We washed the van roof a few days ago using three capfuls of Fenwicks concentrate in 10 litres, followed by two capfuls of Bobby Dazzler in an 8 litre sprayer. There was enough left to remove the runs down the sides. I carry the Fenwicks cleaner, bobby dazzler, and black streak remover in a shoe box. The Jennychem would have taken up a lot of boot space that I needed for the ladder
Has anyone tried wet and forget? I haven't but am thinking about giving it a try.
Used something similar around garden and on plastic greenhouse and it does remove green algae but it takes time. Not sure I’d use it on caravan as giving it a good close up clean allows potential problems to be spotted early.
I have used Fenwicks for several years after trying out all sorts. Found give it the Fenwicks Overwinter and then before first use of the year, Fenwicks Cleaner finished with Fenwicks BobbyDazzler. Find all it needs during the years use is an occasion spray with hose pipe to keep clean as water just rolls off.End of year Fenwicks Overwinter again
None of the above. Muck Off is as good a **** remover as you will ever find. A couple of eggcupfulls (remember them?) in your washer bottle and you will never have smear on the windscreen.
It also moves the dreaded 'black stripes' from the caravan with ease.
In screen wash you still require something to stop it freezing in winter so adding Muc off seems a bit surplus to requirements. A diluted screen wash solution does the job in summer too.
The quick fix is Greased Lightning and its polished shine.
Fenwicks black streak remover for the stubborn marks.
Autoglym special reisin polish once a year before winter
Note I only mentioned removal of breezy deposits, I said nothing about antifreeze to which MO works as an additive. If you want to save a bit of money a bottle of meths equiv to 10% of the washer contents is just as good and usually cheaper.
