What do you boys use for caravan cleaning?
I predominantly used Fenwicks and twice a year followed it with Autoglym Super Resin polish which is gentle. Then during intervening periods washed with Fenwicks and finished using Fenwicks Bobby Dazzler.What do you boys use for caravan cleaning?
Used something similar around garden and on plastic greenhouse and it does remove green algae but it takes time. Not sure I’d use it on caravan as giving it a good close up clean allows potential problems to be spotted early.Has anyone tried wet and forget? I haven't but am thinking about giving it a try.
In screen wash you still require something to stop it freezing in winter so adding Muc off seems a bit surplus to requirements. A diluted screen wash solution does the job in summer too.None of the above. Muck Off is as good a **** remover as you will ever find. A couple of eggcupfulls (remember them?) in your washer bottle and you will never have smear on the windscreen.
It also moves the dreaded 'black stripes' from the caravan with ease.
