Anybody have that foil stuff behind there home central heating radiators? Does it make a difference? If so what is the best stuff to buy π€
Not unless its scrunched up to block and inhibit the air flow, which I don't think the OP had in mind, more lining the wall with a film of foil to reflect radiated heat.I would probably think it slows the convection process, so possibly slows room warm up π€π€·ββοΈ
Cant have cavity insulation as its a old cottage and I just rent. May try the shelf approach.I fitted that years ago. Its made of sponge backing with a fairly thick crinkled aluminium foil on the front. The idea is that it is stuck to the wall behind a radiator (foil towards the rad) and reflects the heat or to a certain extent radiates heat itself BUT it stops the radiator heating the wall.
IMO it does work in a way but the main issue is (a) what do you do when it comes to painting or repapering the wall and (b) it does after some time come unstuck and is the very devil to get back. In fact it is easier to replace it and it ain't cheap or wasn't when I did it.
IMO you would be better to have good cavity insulation and put a small shelf with a curved underside over the top of the radio to push rising heat outwards. Also make sure your curtains are hung so that the rising heat does not get into the window reveal - you want/need it to heat the room after all!
I donβt know, itβs not clear to what they intend π€Not unless its scrunched up to block and inhibit the air flow, which I don't think the OP had in mind, more lining the wall with a film of foil to reflect radiated heat.
Our son has a heat driven fan on their log burner, and it is very effective.You can actual buy radiators with a built in fan, how efficient they are I don't know. My daughter has a heat fan on her log burner sees to work.
We used something similar on a house where a bedroom outer wall tended to condensation. I had tried using anti condensation paint with minimal effect, so used insulated paper which did stop the condensation, so it must have had some effect, although not noticeable in temperature or comfort when using the room.We have a 1930s bungalow with solid brick walls so cavity insulation is not possible. We have double glazed windows (new at the back of the house, being replaced at the front) but it is a rather chilly house. Looking into that insulated wallpaper when we redecorate next year.
Something like this perhaps??
Mel![]()
Wallrock ThermaWall Insulation Paper
Wallrock ThermaWall combines strength and durability to reinforce walls and ceilings. At just 50cm wide, itβs narrower than traditional thermal liner and is much easier to work with β particularly in smaller areas such as window reveals.It creates a thermal barrier at the wall surface, helping...www.toolstation.com
How affective they are depends on where the stove is installed.Our son has a heat driven fan on their log burner, and it is very effective.
Our sons sits in a large enclosed fireplace so not too constrained.How affective they are depends on where the stove is installed.
If on top of a stove in an enclosed fireplace they may help but I have two on top of our free standing wood burner and I tested them with a flame on the fire lighter. After about 15cm they made no difference as the convection currents from the stove itself were more dominant.
I'll get your coat πI suppose if you did it the wrong way you'd be foiled in your attempt to make improvements π
I had many times questioned, "who on earth could write this stuff?" πSorry but I'm too busy writing jokes for Christmas Crackers.
Are you in Australia? "9.30am at night until 8pm in the morning" π€I have tried the "thermal foil" for want of a better word, and being true, in our house with walls of 15 ft by 20 feet, the foil is of very little use.,our radiators are "twin banks" and with a footprint of the largest radiator being 6,ft by 3 ft.,on an outside cavity wall,
Reality is we are heating our homes inside brick walls from 9.30am at night until 8 pm in the morning we lose 3 degrees 21c down to 18c. Which is essentially making the house a storage heater .
we find a comfortable temp, is 18 c during the day and evening at 21c.,this is a large 4 bedroom house. Gas cost us Β£5 on average a day, and Β£2 .50 on electric. . Changes totally in summer to about Β£80. .,
