- Nov 30, 2022
- 1,998
- 1,897
- 5,935
That depends on where you holiday! If in the UK then I tend to agree, but if Soutgern France, Spain or Portugal then it can (and often does) get seriously hotWarm weather is what's often discussed but rarely seen
That seems VERY wrong to me! There should be a "chimney" above the flame that runs up to, and exhausts through, the top vent! Like below (this is on a panel van conversion so the vents are on the back door, hence the back of the fridge being so accessible!My fridge needs it as gas flue exhausts inside fridge cavity instead of running flue outside. Now there is additional heat build from both fridge radiator and gas exhaust. Poor/cheap design. Old bailey had separated exhaust.
If your fridge performs well as it is, then you do not need a fan. But in my last van, the fridge was poor, and we were touring in France. After fitting the fans, the fridge coped with 35 degree heat.Why do people fit the is it better than leaving the fridge as standard?
That is the same as my Alicanto. I hope the fridge is properly room sealed. Even though the fridge works well, I may fit the fans in case we use the gas at some stage.My fridge needs it as gas flue exhausts inside fridge cavity instead of running flue outside. Now there is additional heat build from both fridge radiator and gas exhaust. Poor/cheap design. Old bailey had separated exhaust.
Well we will see what ours like it a big fridge freezer in this caravan see how it performs from tomorrow , but the fans are a option but have to get someone to fit them .🙏If your fridge performs well as it is, then you do not need a fan. But in my last van, the fridge was poor, and we were touring in France. After fitting the fans, the fridge coped with 35 degree heat.
I purchased this fan kit for my new van. But after using the van, we are more than impressed with the fridge. So I may not even fit them.
@mr plod I can honestly say I have never seen a water pump attached/almost attached to the rear of a fridge before. How odd 🤔
Oh that kind of makes sense, I was thinking it was inside a fridge vent somehow 🤔🤣The water pump is firmly attached to a substatial bracket !
Don't forget this set up is on a Panel Van Conversion not a caravan and the picture is taken from the rear of the van with the back door open. The bottom door catch is visible at the bottom right of the first picture. Being a PVC space for habitation equipment is at a premium, hence the location of the water pump. At least its very accessible, as is the back of the fridge.
Have you got your new caravan all set up and working? Nice weather for your initial holiday in it.The fridge freezer has perform very well so far to day been very hot and it very cold inside 🙏
Yes it all set up and working great just need a triple arm caravan tv bracketHave you got your new caravan all set up and working? Nice weather for your initial holiday in it.
JohnTo update.
I have not fitted the fans to my fridge for two reasons.
First, the fridge has worked very well in early 30’s temperatures.
I read the instructions for the series 10 Dometic. Seems it comes with a thermostaticly controlled fan as standard.
Which precise model series 10 John?I read the instructions for the series 10 Dometic. Seems it comes with a thermostaticly controlled fan as standard.
Good question. It is an external fan. These are the instructions.But Is that fan internal to circulate the cold air within the fridge (like my one at home does) rather than an external one to aid air passage over the heat exchanger?
Your fridge works well enough for you, and thats all that matters to you, but many owners find theirs dont cope so well, hence this thread!
I paid so little for them I think the postage might be more than the value. But I will probably do as you suggest.John
You are a rarity having read the owners manual. Clearly old habits die hard. Can we expect a couple of fans to be advertised on Market Place at a bargain price? 😂
Strangely, I don’t know for sure. The instructions that came with it are worse than useless. A list of instruction which all say refer to fig x. Some of that list mentions grills, and ovens! 🫨. Then there are no figs to refer to.Which precise model series 10 John?
There are at least 6 listed.
As we all know from recent threads the exact model number and month / year of manufacture is crucial. Dometic change their specifications very often!
