fridge fault on 240v
Jul 4, 2007
Hi i have just entered the exciting world of caravans and have bought a sprite esprit 1991. all is great and we are set for our first outing the only problem is i cant get the fridge to work on 240v it works fine on gas. I have checked the fuses and that power is getting through (it is and yes i have turned it on at the switch) anyway its an electrolux rm 212f. a local place said it could be the 240 element, any ideas welcome
also i have a crack in the outer skin on front buy the window about 8 inches long im not sure whats best shall i stick it with araldite or silicone it. and is a vauxhall astra going to be ok to pull this 2 birth van
thank for any feedback pete
Jul 15, 2005
2,175
Hi Peter,
Fridge?
If the fridge works on gas, then there are no issues with the internal workings of the fridge - which is good news.
But it doesn't work on 240V, this means that you either have a loose connection or the heater element has failed (most likely).
Replacing the heater element (cartridge) is an easy DIY job, especially if you can reach everything through the exterior vents and don't need to remove the fridge from the housing.
Spend
Jul 4, 2007
Hi Peter,
Fridge?
Spend
Jul 15, 2005
2,175
Peter,
If the panel is actually split, then you need to repair from both sides: From the rear, one or two layers of glass mat stippled on with GRP resin; and from the front grind out the slit into a V shaped groove and fill with self coloured GRP.
If the panel just has a hairline (surface crack) then grind out the crack into a V shaped groove and fill with resin.
It's not a difficult job, just follow the instructions on the resin pack. And regard everything you use to mix, stipple (paint), or spread the resin as disposable.
And if you do open up the inside, check for wet-rot in any surrounding woodwork.
Robert
g1
May 21, 2007
83
Peter,
For your Electrolux 'fridge element try
T. K. Garnham of Ipswich. Phone 01473 275180.
They are Electrolux specialists and I found them very helpful.
G.
3,803
Hello Peter
An addendum to Rob-Jax's pretty full answer regarding the gas system. To comply with the gas regulations you must be competent in the eyes of the law to install, service, repair or remove all gas appliances so that includes BRAKING and MAKING gas joints.
