Jun 17, 2018
50
Someone said to me fridges don’t work offciantly on a slope on your drive as to say any truth in this
4,679
Being a forum member that can decifer, , I believethat the caravan should be within 10 degrees from level for the fridge to work properly .
Jun 17, 2018
50
I’ve read up and it says a freezer doesn’t freeze items it just keeps them frozen till you get to your destination
4,679
Batman, yes, our fridge a dometic, N112, works well small freezer, it will keep everything frozen and will make ice for drinks, so all ok.
Jun 17, 2018
50
My mate said your caravan as to be perfectly level for your fridge to work properly any truth in it
9,358
Batman1957 said:
I may have a faulty fridge here since I’ve just bought it
As said it won’t freeze fresh food but will hold frozen food at a temperature that keeps it frozen. But these aren’t long term freezer storage cabinets. You say it doesn’t work. Is this on elelctric or gas ?
2,316
Hi Batman, if you put an unfrozen item into the freezer box of the fridge, hitch up the van and tow; it won’t freeze it. However, once you are on site and connected to EHU it should freeze. But you need to remember that compression caravan fridges are not as speedy as the fridge at home.
50
Crazy as it seem I said to my wife I think the freezer is faulty it’s not cold enough but I put my beer in the freezer on site and the next day the beer was frozen
9,358
As short term freezer cabinets they are fine but do not operate at the lower temperature achieved by your home freezer. But by their very nature caravan users are unlikely to want to store frozen food for extended periods.
937
Caravan fridges do need to be as level as possible, within a couple of degrees in each direction to work to their full potential.
When on site and connected to the mains, or working on gas the freezer should be just as good as a home freezer, with most rated with 3 frost symbols which equates to 3 month storage capability, and get down to about -4 degrees in the freezer box and around +2 or 3 in the main compartment.
Quote " But you need to remember that compression caravan fridges"
The normal caravan fridge is not a compression fridge, it is an absorption fridge.
9,358
Sounds as if it is working then.
9,358
Home freezers should be -18 deg C or lower.
Oct 12, 2013
3,037
My thoughts too !!
2,316
Yep, that’s what I meant. :whistle:
2,316
Have to say, our freezer box seems to freeze things into a pretty solid state. But you are right, I wouldn’t keep anything in the caravan freezer box longer than I would keep it in the fridge.
5,450
Our Dometic fridge has a removable freezer compartment. If it is not correctly fitted and locked in place it won’t freeze the food.
May 24, 2014
3,687
765
Aye we have one of those daft things. havent used it yet in anger but I will def check its locked in place.
