FULLY SERVICE WATER CONNECTION, NEW IDEA.
4,465
By posting in PC forum you are making your post open to public view and comment and you have no rights to control who comments or what they write, or when a thread is closed.
It is quite common for a forum thread to morph away from the OP's immediate need or intent this is colloquially known as Fred Drift. Unreasonable drift will be curtailed by the Moderators or Forum Management
What is allowed in comments is outlined in the (Forum Etiquette) The arbiters about posted comments are the forums moderators or the Forums Management team and they have a range of sanctions they can invoke if deemed necessary.
If there is a comment you feel oversteps the accepted norms of the forum, you can use the "Report" button in the bottom left hand corner of the post to raise your concerns with the moderators. The author of a reported comment has no automatic right to know if who may have reported an issue, unless the moderators decide to make it known.
Being the Opening Poster in a thread does not give any additional rights to edit or moderate subsequent comments.
4,186
1,913
Aren't most systems in caravans controlled by a pressure switch? If a pipe comes loose in a caravan then no system will stop the caravan being flooded.
I have only in 40 years I have had caravans had 4 , three had micro switches, just one had a pressure switch.
You might well be right in your assumption "most caravans are pressure switched" but they weren't so in my case, along with only owning caravans sold into the UK market.
IMO there is little doubt that is the cheaper option as it does not require the same level of van build labour or componentry, so very likely why its used.
Re the second point, whist arguably "flooding", the extent of that flooding from a pipe coming loose can be very different depending on the system design.
With tap microswitches controlling the supply pump, it unattended would only amount to the small amount of water loss needed to decay any held pressure. Here the pump does not start, thus feeding the flooding.
Whereas, with the pressure switch the loss of pressure from the loose pipe signals the pump to start and then empty the stored water container's contents in to the van, be the van unattended or attended.
3,885
As i said, not for anyone in particular, but if you start a thread, it should closed by the raiser, not someone bored with the responses. tha's my final comment, its never personal unless you make it so. bye
I've never known thread starters have closure control on any forum - threads drift naturally, just like face-to-face discussions, and generally moderators only close threads when they become toxic.
Sam Vimes
2,790
2,268
12,935
There is no reason to delete or lock this thread as the original question and subsequent discussion may be of use to others reading it.
If anyone feels they no longer wish to participate in this particular discussion they can unsubscribe from it. That way you will not receive further notifications of additional posts but the thread will remain active.
4,800
Threads will drift on until the arguments turn towards the inevitable, nose weight, and best way to measure it.
We do have some self appointed Moderators on here at times,
But there is always some good information.
