Just changed my van yesterday, and my old van had the older type gas regulators on. The new van has the new type of regulator. As far as i can see, i need a piece of gas pipe and a screw type fitting to fit the new onboard regulator??? Is that correct??? On my new reg there is fitment for a screw type ending AND underneath the reg is a small valve which looks like a pipe can be pushed onto it. The end piece is some kind of valve. So do i need just the pipe pushed on, or (as i think) pipe with a screw type end to fit???
Also i had on my older van a gaslow changeover system, basically a regulator and gauge that both propane bottles screwed into and it controlled the gas and told me how much was in each bottle. This gauge then was connected to the old valve "end" as normal on my other van (2003 van).
So can this gaslow valve/gauge be compatible with my new vans system??? I only bought the gauge last year.
Thanks.
Thanks.
