Gas not flowing properly
Jul 13, 2024
We are having trouble with our gas supply and believe it’s due to the regulator. Swift caravan (2011) and truma regulator. We’re away now and not near caravan supply place. Hubby is quite handy, wondering if he could install it himself. Another option is a service place in France but would they have the correct parts?
Thanks,
Emma
Nov 30, 2022
1,964
1,851
2,935
The regulator is a universal item, just about any caravan or motorhome accessory shop will sell them.
Simple enough to fit, just be sure there are no leaks ! (Soapy water foam works well)!
5,260
Maybe an idea to change the connecting gas hose at the same time if it has not been changed recently?
968
214
19,135
If using diluted washing up liquid make sure you was it off afterwards as it has salt in it that is corrosive
Reactions: Dustydog and JRT
Jun 6, 2006
968
214
19,135
Thanks,
Emma
Sometimes it can be the non return valve in the pigtail that causes the issue!!
4,034
1,771
Or even better, just use proper gas detection spray.
The OP had told us they were away, by inference in France and not near a caravan place, so I doubt seeking a "proper gas detection spray" is going to be that easy, and just hype up their immediate challenges. Plus, in this context, just using soapy water will be quite effective enough IMO, one less problem.
Reactions: Hutch and Mr Plodd
Nov 30, 2022
1,964
1,851
2,935
Which was the exact reason I suggested soapy water, not ideal, but a pretty good second best under the circumstances.
JRT
May 5, 2024
271
180
235
My comment wasn't specifically targeted at the precise situation outlined in the original post.
It was more a general comment aimed at those who need to seek out a gas leak in the caravan or at home.
Unfortunately I failed to fully detail this in my response, and subsequently when I realised this I decided to leave the post as it was because I knew someone would not hesitate to point the apparent shortcomings in my post.
2,042
720
You don't need specialist caravan dealers in France. Large supermarkets like Auchan and large hardware stores such as Leroy Merlin or Brico Depot are often well stocked with the sort of thing you may need - and often cheaper than the UK!
Reactions: Ferrodo and JRT
JRT
May 5, 2024
271
180
235
Although I have never tried to locate the specific items referred to in this thread I do have to agree, particularly ref. the big supermarkets., when we first started to visit France I was surprised at the range of DIY and hardware stuff some of the big supermarkets carry.
Jan 19, 2002
1,705
546
If you are on site for a few days and speak to the owner you could presumably get Amazon France to deliver for you - a quick look showed Amazon France with English translation.
pigtail example:
Regulator examnple:
priced in Euros.
(Sorry don’t know why it hasn’t condensed the URLs but my intentions were good when I posted!)
