Hi MHThanks John L for taking a more rational view. when I asked the question I wasn't aware that a Gaslow Container could be filled up in any other way than with the a permanent coupling and pipe work (it's not marketed in any other way) and I was hoping that more than one person who have fitted this type of arrangement.
I have contacted a couple of dealers who are happy to install or sell a kit and both have told me of no known safety issues indeed one dealer proudly describe it's installation in a 70K motor-home and I think this may be the nub of the issue that the motorhome fraternity are a lot more keen to adopt this technology (and have). Perhaps because they use their vans more often and/or spend longer abroad.
Thank you once again for calmness in the light of such **** May be John (Or Rob Jax) you could answer my question as you seem to have some knowledge of this area but is filling an LPG (mounted) safer than filling you car with unleaded - re my earlier question on vapour lock in ?
Regards a non emotion Husband of a Monkey
Clive,What are you on MH?
You ask in November about a Corgi engineer checking a LPG installation !!!
Then get all bitter and twisted when, not just me I might add, points out that refillable cylinders on garage forecourts are not allowed/insured.
As for my travels I am off to Brisbane in 2007 for a family wedding - and yes I do have friends in Perth and a niece in Brisbane.
After the wedding we shall be doing what we normally do and take a motorhome on a trip. This time up the coast to Frazer Island and beyond depending on what we feel like.
Quite what my travels have to do with UK H&S legislation has to do with refilling gas cylinders on garage forecourts is somewhat beyond me but I am sure in mentioning it you have your reasons.
In regard to your technical question about mechanical safety (not legal safty) of filling.Thanks John L for taking a more rational view. when I asked the question I wasn't aware that a Gaslow Container could be filled up in any other way than with the a permanent coupling and pipe work (it's not marketed in any other way) and I was hoping that more than one person who have fitted this type of arrangement.
Hello again MHClive,
You clearly need to stop the amber nectar before taking to the keyboard - So I ask a question about whether a technician has to be corgi registered to work on a vehicle - it's a valid question - after all they should to work on a caravan or motor home.
By the way it's Fraser Island not Frazer Island - went there in 1993 - can recommend if a little built up now and overrun with Jap Tourists. Sunshine Coast has a lot to recommend it. I take it you be eating out all the time ?? or will your Barbie solar powered ??
I had a very cold girl ring me from the Alps last winter as she hoped I could find out why her 'full' bottle would not give her any gas.Thanks for that Gary - I was unsure about the methane bit as well but Rob_Jax on a previous post made it clear that Autogas (LPG) is made up of a fair old mixture of the volatile hydrocarbons. Propane is the main one.
John also suggested that the higher ration of Butane in Spanish LPG could be why my LPG system registers as full if I have any LPG in my tank. The higher amount of Butane will apparently provide a lower residual pressure in the supply tank that is not enough to override the pressure in my cars LPG tank as UK LPG has more Propane.
I have no idea if this is correct but it sounds feasible.
Hello Gary,I had a very cold girl ring me from the Alps last winter as she hoped I could find out why her 'full' bottle would not give her any gas.
It turned out she had a refillable bottle (topical!!)and the local service station autogas mix was 60/40 propane/butane, subsequent fills became less and less until she ended up with a full bottle of Butane and no heating with temperature well below freezing. Only answer was to drive down the mountain into warmer climes.
Due to buying a petrol hungry car I have only this week asked a few questions about gassing it up. My limited understanding to date then,(underlined),is UK autogas is 100% propane or near as, it is also the same gas as bulk delivered for home heating, ie Propane, while as we can see it's different on the Continent. This also goes for continental filled blue bottles which I also understand to be a 60/40 mix.
As far as what Johns says,(far be it me to argue!),Butane bottle pressure is around 25psi at a given temperature while Propane would be 125psi at that same temperature, ie, much higher at any given temperature. Does that help?
Clive,I have my caravan gas system pressure checked every year and changed the rubber pipes as a matter of course on purchase (it was not new). It then gets a sticker to say that this has been done and the invoice goes in with the log book and makes up its "service history".
The main difference between a car based system and a caravan based system is that the cylinders are detachable and the pipes leading to the caravan appliance can go via connections and "T" pieces so that multiple appliances can be fed from the one source. The caravan system is like a household gas supply - i.e. it really is a GAS in the pipe.
Hence the need to pressure test.
The situation on a car is very different in that the LPG travels to the vaporiser as a liquid. Also, the tank(s) do not have a manual valve. Therefore if the tank is situated within the body/boot of the car (as a cylinder is within a caravan) the pipe must be enclosed in a sturdy outer pipe that vents any leaking gas to atmosphere outside the car.
The pipe on a car takes the LPG as liquid unlike in a caravan that takes the Propane/Butane as a gas to the appliances. In a car, the LPG is heated in the vaporiser and fed to the inlet manifold according to throttle demand.
So the two systems are substantially different.
So please do not take this the wrong way MH, but it is clear to me now that you are equating any gas system with that of a house - hence your comment about Corgi engineers being able to work on Car LPG systems.
Should be clear to you now that a car LPG system as it carries the LPG in a liquid state and then has to provide a graded supply at the inlet manifold according to throttle response engine load etc.
One further query I thought of today is that Liquid Petroleum gas is a mixture of mainly Propane, a fair bit of Butane and a little Methane.
Gaslow state that LPG is Propane which is not entirely correct because LPG is not entirely Propane.
I have never used anything other than one type of calor gas cylinder but thought that if you did need to switch due to winter caravanning, then a different regulator was required? One for Propane and one for Butane.
So what happens when you run a mixture of the two?
Any thoughts anyone?
LPG to me is a group of gasses and confuses the issues, much better to call it one or the other or 'mix'.Hello Gary,
Your are quite right about the relative pressures of butane vs Propane. I only alluded to the Propane as that is the major constituant of LPG for motive power, and it is also the fuel that would be available for refillable portable bottles.
I do not know of any retail outlet that self butane to refil bottles - butane is almost exclusivly used for rental or single use systems, (Cigarette lighter refills being the exception)
Glad you illuminated on the scout story John, I had images of little scouts stood neck deep!! It does remind me though of a 'camp' in Snowdonia not scout but school when the milk kept going off due to the heat. I had the 'bright' idea of standing the crates on the boulders in the mountain stream passing through the site.With respect of your chilled child!
Her sad experience demonstrates another difference between Butane & Propane. Butane requires a temperature of more than -4C to be able to vapourise at this temp, it is very lazy and will not provide enough pressure to run caravan gas system,in practice it the temperature needs to be about 5C or more so that there is enough heat available from the atmosphere to keep the bottle warm enough to keep the gas vapourising.
Propane has exactly the same operational process but it all happens at about -40 - which is well below normal environmental caravanning & camping conditions.
I have implied that the bottle needs a warm atmosphere to allow it to work - and so it does. As the liquified gas draws the energy to change phase (liquid to vapour)from the heat of the body of liquid. In doing so it actually cools the liquid and the container, which explains the dew ring you see on some bottles when they are used. This change in temperature of the liquid is also used by some gas bottle volume indicators.
If the amount of gas used is great, then the cooling continues until there is insufficient heat left in the bottle to continue the process and the vapour pressure falls.
The self cooling effect is determined by the amount of gas you are using. It is also the reason that Butane only really works at 5C and above because it self cools to a lower temperature. Propane is teh choise of commercial opperators because it will continue to work at all year round. In fact if you see roofing contractors at work you will usuall see ared gas bottle with a layer of frost, because they are using the gas at a very high rate to melt the bitumen.
Where butane and propane are mixed, each gas retains its individual charateristics, so as the temperature drops, the propane will continue to vapourise, whilst the butane remains in its liquid state.
I have seen some people make the mistake of wrapping thier butane bottles up in an insulating jacket - 'to keep them warm'! It actually makes the problem worse, they need to be in free air where thay can absorb heat from the atmosphere.
If you do get stuck with cold weather and butane a short term solution is to pour a bucket of water over the gas bottle. The water will be warmer than the air, and will contain much more heat energy than the immediate air. It will give you enough gas to boil a kettle for the all important cup of tea.- A trick I had to use onteh Norfolk broads one October - A bucket or two of river water provided enough warmth to the gas bottles to get us going. A Similar problem happened with some Scouts. we stood the gas bottles in the stream just behind the cook tent and breakfast was cooked.
Any one for bacon & eggs?
