I suspect I may have a problem with the habitation relay not dropping out when the car ignition is switched off. Fridge and charging appear normal whe engine running. But when engine ignition is turned off the van electrics stay inhibited - ie can't select or get any 12v supply whether van or car battery is selected. I am fairly certain the car supply is ok. (99%) (But am going to check again when I get home) So I suspect the habitation relay is not dropping off.
Van supply normal once 13 pin plug disconnected, but bit of a nuisance when en route having to diisconnect car to run pump or loo etc..
Just a simple question really - where is the habitation relay physically placed on the van, so I can have a look to see what happens - ( the van is 2009 Sterling Europa 520.)
