Has anyone wired up a 12n socket to an old shape mondeo ST td...
Jun 1, 2008
16
Has anyone wired up a 12n socket to an old shape mondeo ST tdci hatch? If so do I need a bypass relay? The new ones do, but I don't think the old ones do, but wanted to check with someone who has perhaps done one before? Any help gratefully accepted!!
ctj
Feb 16, 2008
53
Hi i have a 2002 1.8 zetec when i fitted my own towbar and electrics i looked in to this and it turns out that if you have the onboard computer (most models above zetec)you need the bypass relay if you dont have the onboard computer (which i dont) then you dont need one my lights work fine!
Mar 12, 2008
72
hi john i did 1 of these not so long ago got my parts from towsure
you need a 7 way smart bypass relay (code H52) and a pre-wired N type socket
on the ST you can run your live feed straight from the battery along the under side of the car down the drivers side as were the brake pipes are seated there is a spare set of clips along the length of the car
the bypass will sit snuggly behind the passenger side rear light cluster as theres a indent in the mounting plate for the lights hope this helps
Graham
