I thought I'd post a warning following a monumental error made by me earlier. After a catalogue of problems with our caravan we have changed it, I needed to remove the Isabella wheel arch draught cover strip which is fixed in place with 3M tape, as usual I used a length of MIG welding wire and carefully sawed through the tape like a cheese wire, no issues but there was a lot of tape left stuck to the panel. I decided to use my wife's hair dryer to soften the tape up to remove it, this is where things went horribly wrong........
I used the dryer on it's highest setting and held it close to the panel, I have a fair bit of experience with GRP and knew it was tough stuff (I now know different). As I heated the first bit the tape softened but suddenly the GRP surface started to go out of shape, in a panic I removed the heat and pushed the blisters back down, creating an indentation in the panel!!!!
It turns out that the outer GRP skin on Swift's really is very thin and nowhere near as robust as I assumed. The rest of the tape was removed "cold" by picking it away. The damage is about 5" x 3" and obviously needs repairing. Honestly, I could have cried. Only myself to blame, the dealer will get it sorted when we take it in but it'll be costing me between £300 and £400! If we were keeping the caravan I think I'd add a vent cover over it!
I'm not looking for sympathy as it's my own daft fault but I have read before of people using hair dryers to remove tape etc, just be careful folks, it really doesn't take much heat to go out of shape.
