What about battery and gas bottle(s) too? There is bound to be some preload into the dampers as otherwise they would rattle and wear. Are the both the same compression?The dampers of my hobby 460 UFE are heavy pressed but the caravan is new and is empty.View attachment 36
i have air conditioned, movers and awning and nothing else.
Is this normal (photo)?
Don’t forget 21-25kg fir a battery too.Going on what has been said so far it seems that with just what you have you may be close to max before adding anything else.
Max MTPLM 1350Kg
MRO 1200
Your list of items 116Kg
Spare available: 34 Kg
However, as the damper is rated at 1300Kg with just the MRO and your items listed you are at 1316Kg, already 16 Kg overload, with the extra 34Kg the overload would be 50Kg
This is all hinting that these extras have been fitted to the lighter rated chassis, not the uprated chassis.
If these were fitted pre delivery by the supplying dealer, then IMO there is a case against the dealer for the transaction to be covered by the Consumer Rights Act 2015 legislation. As a package, it is not fit for purpose, and the supplying dealer had an obligation to point out the kit requested was not viable on the base caravan.
If it was a single transaction I would seek legal advice from Citizens Advice or your own solicitor.
Jojo lives in Portugal, so probably did not purchase his new Hobby caravan in the UK where the Consumer Rights Act 2015 is in force.
Assuming that Portugal was where he obtained the caravan, consumer guidance is here
https://europa.eu/youreurope/citizens/consumers/shopping/guarantees-returns/portugal/index_en.htm
Hobby’s website provides a fair amount of detail about the weight of their caravans in standard form and the weight of add-ons that can be factory ordered, and it’s plain from those data that a 460 UFE model on the standard chassis (which Jojo’s caravan has) would be close to the 1350kg maximum technically permissible gross weight when the items he has listed are taken into account.
As the following link shows, Knott offers a number of caravan chassis dampers
https://www.knott-trailer.co.uk/chassis_damper.html
with the two ‘green’ dampers (Part numbers 990201 or 990205) both quoted as being appropriate for single-axle chassis with a 1300kg weight range. The ‘blue’ dampers are intended for an 1800kg weight range, so MIGHT be used if a 460 UFE has the 1500kg chassis. However, none of these dampers are spring-type, so replacing the green dampers on Jojo’s caravan with blue dampers would not change the ‘compressed’ length of the dampers once they had been fitted - all it would do is stiffen up the caravan’s damping.
Jojo has said
“...the axle is already at the position of fully load (almost in horizontal position).
Hobby don't give a margin for the torsion rubber?"
It MAY be, if the 1500g version of the 460 UFE model is specified, stronger rubber ’springing’ and stiffer dampers are provided to cope with the higher maximum weight - so it MIGHT be POSSIBLE that Jojo’s caravan’s springing could be adjusted so that the caravan rides higher and the dampers will have more available downwards movement.
Jojo is clearly uncomfortable over the axle’s position and the dampers’ length, and the logical course of action is for him to contact the caravan’s vendor and ask what can be done to address those issues.
i'm sorry, gas bottle are 6kg each.
Sorry Damian, i didn't notice your posting.I have a question about the gas cylinders.
You state that you have 2, but what size are they or are you quoting the contents , i.e 6Kg x2
If that's the case, then the actual weight will be a lot more as the cylinders weigh around 7Kg each plus the 6Kg
gas, making 13Kg each, x 2 = 26Kg
I'm enlightened, i have to change something, i will contact Hobby.
When buying the seller did not alert me to excessive weight.
thank you very much
Thats alreaady been said in previous Postings.The specification of a De Luxe Edition 460 UFE is provided in some detail on this Hobby website’s datasheet.
https://www.hobby-caravan.de/en/caravans/de-luxe-edition/model/modeldetails/showPdf/Model/460-ufe-4/
It will be seen that a 460 UFE’s gas-locker can accommodate two bottles and (as the caravan is German-built) the bottles can be the usual Germany-norm 11kg-capacity type.
JoJo has said that he has 2 x 6kg bottles and - assuming these are Portuguese bottles - each will weigh 13kg to 17kg when full. (A 6kg-capacity Portuguese bottle may contain butane or propane gas and may be metal or composite construction, but the weight of the bottle when full won’t differ much whatever gas is in it or what the bottle is made of.)
It should also be evident from the Hobby datasheet that the basic specification of a 460 UFE is a lot less comprehensive than might be appreciated when compared to UK-built caravans, and that the addition of ‘invisible’ heavy extras (spare wheel, autonomy package, 47-litre inboard fresh water tank, etc.) will rapidly gobble up the already limited payload of the 1350kg-chassis version.
