Help = Found window delamination whilst on holiday in France
Aug 31, 2008
516
18,885
Hi
We're on holiday in Benodet, Brittany and I've just noticed that our front nearside window has delaminated along its bottom edge. The c'van is a 2006 Bailey Senator Arizone I've done some research via Google and it looks as though a new window will be required, although some folk have attempted repairs with specialist adhesives. All the posts on caravan forums seem to be at least a couple of years old. I note too that in the past the manufacturers' have given discount on replacement windows as it is a known problem.
However in the short term I am wondering if the caravan is towable as we are due to leave here on Friday 24/08 to drive 70 miles to Roscoff and then on Monday 27/08 a 300 mile drive home from Plymouthto St Helens, Merseyside. The English leg will be mainly motorway driving c50mph. I could tape up the window edge with duct tape as tI have read the outer layer could become detached.
I do have Red Pennant insurance and so they would probably send out a new window but if a replacement is necessary I would prefer to try and source aecond hand one from a breakers.
All comments both on the long term solution (repair/replacement) and short term (drive home) are very welcome.
Tim
Sep 4, 2011
600
369
19,135
If it is only along the bottom i would open window and put some duct tape along folding it up so that it is stuck to inner and outer of window.When window is shut this will then stop any air pressure getting between the two when towing and opening it up further.
Jul 15, 2008
3,901
1,088
I agree with birdman.......you can't beat a bit of Duct tape for a temporary caravan repair!
Sort it out permanently when you get home.
Aug 31, 2008
516
18,885
I think I will be using the duct tape temporary solution. Anymore thoughts anyone. I think my wifi payment expires about 13.OO French time (12 noon UK) so I won't be picking up any forum posts after that time. SO anymore good ideas please post SOON!!!
Tim
Aug 31, 2008
516
18,885
Tim
Nov 5, 2006
805
I used this company for a repair to my Pageant front window which had completely delaminated http://eeco-ltd.co.uk/
much cheaper than a new window .
if you want to try a repair yourself be aware that tthe above company will not attempt a repair on a "contaminated "window
personaly for £90 I went for the proffesional option
BUT this is available on ebay http://www.ebay.co.uk/itm/Caravan-Campervan-Window-Repair-Sealant-Completely-Translucent-from-Germany-/261079047193?pt=UK_Campervan_Caravan_Accessories&hash=item3cc9861c19
PS do not remove the top metal hanging rail from the window as you will never get it on again
Dec 29, 2006
18
Hi, I repaired a delaminated window a couple of years ago on our swift conqueror- and its been fine ever since. I used DOW CORNING marine silicone-it has good temp. flexibility. I simply removed window , put a small bead around and clamped it up with some small crocodile clips, Once set, simply remove any excess with a sharp knife.From the sound of yours,you could probably do it in-situ. Remember, just a 2-3mm bead as when the two faces ate put back together,its surprising how it spreads. I posted the repair on here when I did it. hth,stuart1
Sep 15, 2006
270
I used clear duct-type tape when the window came apart on my caravan, for about 4 months, with no issues.
