Help with cassette toilet
Oct 4, 2025
Hi i have a lunar quasar 526 ive figured most of what does what but not sure what the small pipe above the cassette box/toilet in the outside hatch is. Its a small black rubber tube with a cap on that when taken off it releases water. I think its to empty the flush tank but not sure any help would be appreciated
Aug 1, 2025
Hello Andy Jack. We have a 524, aka Eclipse, our first caravan. We started caravanning in our 70's so we were asking these questions a short while ago. The pipe is indeed for draining the toilet flush tank. There are experts on here who will tell you about load balance etc., which is why this forum is so brilliant, but the large amount of water in the tank must put some weight on the offside. Draining the tank is one of the final jobs on our packup routine.
4,556
Yes, the small tube is indeed for draining the flush tank, I always leave a couple of litres of flush fluid in the tank for on route, non planned stops.
It's more important to drain down the water heater, that will save 10kg of. Caravan weight.
9,067
My last caravan had a 45%-55% makers weight imbalance side to side. Adding a battery only made it worse. Water heater, spare wheel, battery, power electrics, fridge, sink and oven were all forwards of the axle and to the offside. But once loaded it towed very well but unloaded it was very nose heavy so unavoidably stuff had to go behind the axle.
Like Hutch I kept 2 litres of fluid in the cassette and 2 litres of water in the flush tank, for comfort breaks if required en route. Oh and no prizes for guessing which side the loo was on.
619
491
1,135
As above, it’s to drain the tank. I only use it it in winter to completely empty the tank so there's no water in there to freeze and damage the pump. During warmer months I just use the to flush empty the tank before traveling.
4,556
Yes, my Predictive texting didn't "measure" up to my expectations. Sorry.
Whilst away a couple of weeks ago, Mrs H, went to flush the loo. Nothing, no whirr of the pump. I gently pulled away the top sticker on switch cover, measured for power, yes that's there. Unscrewed the small cover into the flush tank, pulled the pump out, the impeller was stuck, using a small screwdriver, rotated the impeller and it unstuck. Lots of limescale around it. But not bad for a 13 years old, pump.
Oct 17, 2010
1,320
563
I always drain down before a journey.
In the winter after draining down I refill with about a litre of good quality car screen wash.
9,067
I would have a couple of litres in the cassette and in the flush tank. But for winter like Dave screenwash went through it.
Oct 4, 2025
So keep around a liter in the flush and cassette but drain everything for winter and flush through with screen wash ? What about the drain switch on the water side, would you close that off or keep it open as ive been leaving it open after emptying till i use again. Also ive got a cover for it to cover for winter but some people are saying to cover it and some say don’t because it will trap the damp air. Any help please. Sorry for all the questions but this is all new to me and if you don’t ask you don’t know.
Reactions: DaveA1 and Hutch
Oct 17, 2010
1,320
563
Leave it open. so that if you are traveling home it will drain a lot more water out as you bounce along the road.
Then there is less water in the system, when you blow down for winter.
