- May 7, 2012
- 8,595
- 1,819
- 30,935
seth1 said:I cant see a problem here as long as the trailer wieght is kept to 1300kg.It might be 100% but as we are reminded its only a recomendation.Load the van and wiegh it,forget the mtplm as you hopefully wont load as high as it.If the van and car was empty you wouldnt have a problem so just take the bare minimum.
I am afraid the law requires the B+E licence if the plated maximum weight of the car and trailer exceed 3,500 kg and not loading them to capacity is not an alternative nor is keeping the load on the caravan relevant you have to assume the maximum figures. You can still be prosecuted without exceeding the weight limits these days. I think this is because prosecuting someone after an accident would be impossible if they had to prove the weight of a wrecked trailer.
If you can change the car and have not yet found the caravan then a car with a higher towing capacity is the best bet as it will give you more choice assuming you get the B+E licence.
