smd
Mar 21, 2022
27
It is obvious that towing a caravan can affect your miles per gallon by quite a bit, but I'm just wondering to what extent it is affected. Does the type of going vehicle you have also have a role to play in this, or is it simply down to the weight of your caravan?
Sep 24, 2008
919
238
19,135
Done this last year on a 80 mile trip. With caravan 33 mpg , solo 60+ mpg . Both at 60 mph. Motorway most of way.. I do keep log on all our vehicles and over 70k caravanning and solo it worked out at 42 mpg
6,281
Petrol cars tend to suffer more than diesels. Mine can average around 35mpg solo on a motorway but towing on motorway anywhere between 19-22 mpg.
2,892
It is a variable, wind, weight of caravan, the area which your driving, if your on a flat motorway, or on a hilly section for 150 miles.
The more powerfull the car probably the less difference between solo and towing mpg.
Reactions: Dustydog and smd
6,281
Do you have any tips on what to look for in a towing vehicle that might help with the mpg?
Yes, buy a diesel. Seriously though there will be differences between makes. My XC70 D5 auto only managed 40 mpg going to Krakow solo whereas a Superb 4wd estate auto would do 50-55 mpg solo. This difference was reflected in their towing figures. Most peoples towing mileage is far less than solo particularly if they use the car every day. So considerations need to be given to car mpg, weight of car, body shape of car (estate, SUV,) and intended caravan weight
Reactions: Hutch and smd
Nov 12, 2021
353
316
1,935
Hi SMD and welcome to the forums.
Unfortunately, towing has a massive detrimental effect on MPG, there is no escaping this simple fact.
A caravan isn't the most aerodynamic of beasts and even the lightest caravan will reduce MPG due to wind resistance. The heavier the caravan the harder the towing vehicle has to work to maintain a reasonable road speed during the journey.
There are also variables to take into consideration such as:
  • the time of year, petrol and diesel vehicles are more economical in warm weather.
  • the weather, high winds can be good or bad depending if you are driving into the wind or it's pushing you along. Heavy rain, fog and snow will all affect your driving style and therefore mpg
  • the terain, hills are a killer because you have to put your foot down more to sustain speed
  • stop start traffic where you are using the lower gears. Motorways and dual carriageways are by far the best bet for higher mpg because speed can be maintained over greater distances, in theory.
  • the performance of your vehicle, a more powerful vehicle is going to be more economical than one where lower gears have to be used to maintain progress
  • type of fuel, quite subjective but before Mr Putin went berserk I was using Shell V-Power diesel and I found I was getting much better MPG that it justified the extra cost at the pump. However, I think I might be returning to supermarket jungle juice now though, thank you Vladimir...not!!
  • the speed you choose to travel at. When I first started caravanning, I wanted to hit the speed limit every time. I didn't want to be the shed dragger holding everyone up but it comes at a cost. I've realised something as I enter my 63rd year, "the older I get, the faster I was". I'm now happy to follow the heavies who are on their limiter at 56mph on the motorway. Remarkably, this simple trick has increased my MPG on the motorway from around 24mpg @ 60mph to around 30mpg @ 56mph. On one occasion through a quiet section of roadworks on the M1 with a limit of 40mph my MPG climbed to 38. So, the need for speed while towing is going to cost you dearly.
This is by no means an exhaustive list but I hope it helps answer your question.
smd
Mar 21, 2022
27
This is super helpful! thank you!
3,585
Work on the basis you will get 50,% of the solo figure, It may improve as you lighten your right foot and reduce speed . 56 to 60 mph will cost quite a significant fuel burn than you think.
Reactions: JezzerB
Sep 26, 2018
625
187
10,935
I don't agree that diesel is the answer... Our Kuga towing would do 23-24 against 46-48 solo (50%) the Volvo does about 22 against solo 36 about 61%...
Reactions: JezzerB
2,091
Over nearly 40 years of caravanning, my outfits have been very consistent - the towing mpg is 2/3 my solo mpg - that's across small and large cars, SUVs, 2wd and 4wd, petrols and diesels, manuals and automatics.
198
19,235
jondogoescaravanning.com
A gentle right foot. :oops:
My tow car for the past 15 years has been a 2 ltr diesel estate car. On a motorway run it can give 60mpg with a daily average of around 50mpg. With the caravan, it varies between 28mpg and 32mpg, depending on speed and how the van is loaded. UK touring is quite light whilst going abroad there's rather more gear.
The best towing fuel consumption I've ever had was when I had to do 120 motorway miles in Spain, but limited to 45mph in fifth gear because of snow-covered roads. My average was around 36mpg.
1,781
547
+1.
Have you got a Passat Estate as well?
3,453
32,935
In the Jeep we get 32mpg solo, but towing we get average 22mpg. However it is a 3.0l diesel towing a 2000kg caravan plus jeep is loaded with gear.
Jul 19, 2021
518
349
2,135
VW Tiguan TD 4Motion towing a 1400kg Bailey 40 mpg round town, 50 mpg on a long run 33 mpg towing
Hyundai Santa Fe 2.2 AWD towing a 1700kg Bailey T/A 33 mpg around town 38 mpg on a long run 24 mpg towing
Reactions: Beachball
650
lutzschelisch.wix.com
Regardless of whether I've towed with a petrol or a diesel, as a rule of thumb it's always used about 50% more fuel. A hybrid was the exception, depending upon the conditions, it used up to twice the amount. This was because solo it relied more on electric power and less on the ICE, but towing it was mostly on full power from both sources.
2,078
I have VW Tiguan TDI 4motion Dsg towing 1366kg 40 around town and so far on motorway 46mpg Towing 29-31mpg
So far the car done less than 14,000 miles might do more later
Reactions: Bluetonic
3,134
Hello SMD,
There are many aspects of how much a vehicles economy is affected by towing. Paulus's comment #7 was fairly comprehensive, but there are some basic aspects which apply whether solo or towing.
Air drag is has the greatest effect on constant speed economy. If you double your speed, you need 4 times the power to maintain it, or the square of the speed difference. Generally at speeds above about 20mph air drag is the predominant energy sink. Also its worth speculating that if there were no reduced speed limits for towing, that its highly likely most tow cars would see constant speed economies of 50% or less when towing compared to solo.
As cars have modernised over the decades, modern manufacturing processes have allowed car makers to improve how slippy they are and now its quite to see Coefficient of Drag (CD's) values of between 0.25 and 0.4 or better.
Low CD's allows the vehicle to slip through the air more easily, thus the same speed can be achieved with a less powerful engine resulting in better mpg. But it also means that when you strap on a caravan (akin to an aerodynamic brick) to the drag factor becomes even more significant part of the combination.
Weight is also a factor but its effects are more noticeable when accelerating. This often exacerbated becasue caravanners are used to the cars solo performance when accelerating and they try to repeat it when towing.
You can affect your towing economy quite noticeably by limiting your top speed, and by keeping your caravan as light as possible and accelerating more gently.
3,453
32,935
Today drove down the M5 at a steady 60mph doing 100 miles solo. Consumption 32.6mpg. Coming back same route towing caravan 19.8mpg at 57mph as it is all uphill from Weston Super Mare. I know for a fact that towing down the M5 to Somerset we get at least 22mpg.
650
Drag coefficient of the towing vehicle is insignificant when towing because that of the caravan behind is so abysmal that it overshadows everything that the car can testify.
Reactions: Tobes
3,453
32,935
Also need to take into consideration the type of gearbox fitted into the car i.e. CVT, torque convertor etc.
One thing I noticed yesterday when towing the caravan back from Somerset and travelling at a lower speed is that the car seemed to change gear more often from a high to a lower gear which then amounts to higher revs and more fuel used.
I am not sure however if this balances out i.e. towing at a higher speed less gear changes, but using more fuel or travelling at a lower speed, more gear changes and using more fuel on gear changes?
