I know you old pros are probably fed up of explaining, but could some one tell a wee novice like me, how do I measure the nose weight of my fully loaded van? (please keep it in simple terms!) I'm towing with a C250 Mercedes estate. Thanks, Emmy.
Jokin' aside, in simple terms you won't be far out if you place your jock on to a set of kitchen scales on level ground. Cheap (
John, I am more than happy to accept that there is a small difference between the jock measurement and the actual hitch measurement. However, is it correct that the hitch figure will be lower than that at the jock - I would have thought it would have been heavier as it's further from the axle - but then I'm no expert...Hello Colinn,
Using the jockey wheel as your load transfer system could make quite a difference. It all down t the distance between the main axel and the point of support used to the load to the scales.
A jockey wheel is set back from the actual hitch, in some cases about 0.5M. and it also depend on which way the jockey wheel is facing, When you consider that the distance from the hitch to the main axle is only likely to be about 3.5M. the difference of 0.5 is significant by about 1/7th. Or about 14%. (this figure depend on the geometry of the caravan and will vary for different models)
Fortunately you will be erring on the side of safety, as a 75kg at the jockey wheel will only be about 64.5Kg at the hitch, however that 10.5kg difference could be the difference between a stable and
Thanks for that - you live and learn!! Much appreciated for putting me right...Hello Colinn,
Its basic physics of levers and turning moments.
It is easier to lift the front of the caravan by using the handle on the hitch, than if you try to lift it using a grab-handle on the front of the coachwork. This is exactly the same principal that I described, but a more extreme example, and one that you can try - but watch your back!
The hitch is actually a lever that pivots about the main axle of the caravan. The further away (or longer it is) the less force (or lower nose load) is exerted. Conversely, the body grab handle is closer to the axle (or a shorter lever) and the force will be greater.
In fact if you double the distance or the length of a lever you only need half the force to move it, so there is a direct proportional relation ship.
Consider a wheelbarrow. It uses long handles to make it easier to lift the load, or a pair of cutters is easier to use with long handles than short ones.
Hope this helps
Hello Lutz, thanks for that, my garage is on a slope so i'm going to see the differance by doing it both ways as my feeble brain still cannot see it.Robert, as one measures the noseweight with the coupling at the same height off the ground as when the caravan is hitched up to the car, the caravan will follow the same angle as the ground on which it is standing. If it's a downhill slope, for example, the caravan will tilt forward, bringing the centre of gravity further forward. This, in turn, has the effect of increasing the noseweight to a value that is higher than if the caravan were standing level. Of course, if the ground is facing uphill, then the effect would be the opposite.
Does your garage really slope that much? If it's only a couple of inches over the whole length, it's not going to make an appreciable difference.Robert, as one measures the noseweight with the coupling at the same height off the ground as when the caravan is hitched up to the car, the caravan will follow the same angle as the ground on which it is standing. If it's a downhill slope, for example, the caravan will tilt forward, bringing the centre of gravity further forward. This, in turn, has the effect of increasing the noseweight to a value that is higher than if the caravan were standing level. Of course, if the ground is facing uphill, then the effect would be the opposite.
Hello Lutz the part of the drive which i keep the caravan slopes 9inches in 22 feet, i have posted elsewhere on Foram the results of my noseweights which i done today, perhaps if you find it you would be kind enough to comment on them .Regards.Does your garage really slope that much? If it's only a couple of inches over the whole length, it's not going to make an appreciable difference.
