Who's being "forced" away from diesel cars?I am thinking about what car to get when I am forced away from Diesel cars . Most hybrid cars I look at appear to be weight restricted . I have a Bailey Pegasus GT65 Rimini MTPLM 1470kg .
So I am after like a 2 year old car that can pull this weight.
Anyone got any ideas or advice thanks
The regeneration works by using the electric motor, in reverse, as a generator, the actual brakes are not utilised in any way. As the car slows down the motor/generator resists and in doing so generates power, think of it as an additional (huge) alternator.Remember you won't get the hybrid advantage when towing as the regenerative braking only works for the car's brakes.
I am not getting into the whether or not you are forced from diesel. I am also looking at PHEV options for the further on future as an active choice. I will also be interested in any suggestions for decent PHEV options with good towing capacity.I am thinking about what car to get when I am forced away from Diesel cars . Most hybrid cars I look at appear to be weight restricted . I have a Bailey Pegasus GT65 Rimini MTPLM 1470kg .
75kg noseweight is ok with a 1500 kg MTPLM, it's 5% which is typical for cars/SUVs sold in UK/EU.RAV 4 is restricted to 75kg nose weight. I tow with a 2023 Kia Sportage GTLS FWD HEV and it's great. Be very careful and only take the weights on the car plate as my car varies from 1650 kg down to 1250 depending on in production changes. I tow 1600kg and it's brilliant
Ok thanks I will take a look on auto traderWho's being "forced" away from diesel cars?
You need to give a budget and/or capacity limit for your car purchase - there's certainly several expensive hybrids which will tow that weight - eg VW Touareg hybrid has a kerbweight of 2,360 kg and a towing limit of 3,500
Whats the engine size? Petrol or diesel?RAV 4 is restricted to 75kg nose weight. I tow with a 2023 Kia Sportage GTLS FWD HEV and it's great. Be very careful and only take the weights on the car plate as my car varies from 1650 kg down to 1250 depending on in production changes. I tow 1600kg and it's brilliant
RAV 4 noseweight is 70kg but the PHEV is nearly 2 tonnes so has no problem handling its 1500 kg caravan as reported by owners on the Toyota Owners Forum.RAV 4 is restricted to 75kg nose weight. I tow with a 2023 Kia Sportage GTLS FWD HEV and it's great. Be very careful and only take the weights on the car plate as my car varies from 1650 kg down to 1250 depending on in production changes. I tow 1600kg and it's brilliant
That post could have been written about EV's too... ;-)Plenty of hybrid cars with decent towing limits out there. Sometimes folks get concerned about rumours they've heard rather than actually seeing manufacturers figures.
Look very carefully at the exact spec/model you're interested in as some towing limits vary quite a bit between variants. It isn't anything new though, some of the Mondeo's a few years back had a huge range of towing limits. Hybrids are great cars and there'll be one to suit your needs. The VW group also have various models with healthy towing weights and decent ranges on EV only.Thank you I will look at this
That will depend on the way the. Car manufacturer implements. The regent system in each model of car, but certainly in my Passat GTE, the regen braking certainly does work whilst towing, In fact it works harder as the system has to compensate for the increased mass of the outfit. Don't forget the trailers overrun braking always has to develop some speed differential before the trailer. Brakes can activate....Remember you won't get the hybrid advantage when towing as the regenerative braking only works for the car's brakes....
Fully agree your views backed up by real world experience. One reason we opted for a Toyota was the long warranty that’s renewed annually each time you have a Toyota service at a franchised dealership. In fact if timing is spot on the warranty on the car goes to 11 years if you service it just before it’s 10 birthday. Batteries too at 15 years ( plus1).We have been towing with PHEV for nearly 6 years, originally 2020 Mitsubishi Outlander PHEV ok but nothing special, we now tow with a Suzuki Across (rebated Toyota RAV4 PHEV) excellent tow car 50 mpg plus with a depleted battery solo, towing we see around 32/34 mpg, with a depleted battery 29/30 mpg.
As regards the 75 kg noewight we have notice zero issues. You are looking around £22,000/23,000 for a 25,000/30,000 vehicle. after 3 years our battery is still as good as new, if you have main dealer service the vehicle and battery has a 10 year warranty.
Would I go back to a diesel NO.
There are no Diesel Sportages since 2022, it's a 1600 petrol hybrid (avoid the mild hybrid like the plague - hev or phev only!)Whats the engine size? Petrol or diesel?
