- Jan 20, 2023
- 1,214
- 1,052
- 2,435
If running in full auto-EV mode the car will use both power sources to suit the best efficiency if the in-built sat-nav is used (the car knows where you're going and how you're getting there hence "does it's stuff").I would think that if towing there will be zero difference as the car will probably never switch to EV mode? In addition, many hybrids and PHEV have a much lower towing ratio than the same ICE engine. Not sure if this is the same for a diesel PHEV?
Towing capacity for some PHEV's is a bit of a lottery, the Hyundai Tucson (and others) seem to have varying limits depending whether it's a plug-in or self-charging version and (I think) the latest Kia Sorento hybrid has a very low limit. Others (Audi and Volvo as an example) have towing limits the same as their standard ICE alternatives.
