Hymer Nova battery charger replacement
I have just had to replace the charger in my 2007 Hymer Nova, this the second one, the first "blew" after a couple of months, so replaced under warranty. Not in my wildest dreams did I envisage another one going. But it did (now outside warranty) the replacement has cost a total of £536.66 plus the cost of a new battery. We were away when the charger blew and I did not realise until the battery started failing, so ended up with it not retaining a charge.
Has anyone else had this problem?
3,907
1,649
A colleague has twice had his repaired by Schaudt for a fraction of your replacement cost. Its probably a 2004/5 Hymer Nova and I recall a price of about
3,907
1,649
An interesting link, thanks.
The bit that worries me is the reference to "shifting the neutral point".
I have encountered in France a situation where the phases were out of balance, the neutral was 60volts above earth, but my Schaudt Unit survived.
I was looking at the OVP 01 to use my Honda generator with more confidence, but that article and my French experience indicates I ought to buy one anyway.
3,907
1,649
In my colleagues case the actual time of the charger failures was unknown in that the battery was still being charged very effectively when he was towing. It was only when on site for a long time he found it was not being charged from the EHU.
He had travelled to France on both occasions before knowing the Schaudt had failed, so out of balance phases could well be the cause of his failures. Interesting?
Apr 14, 2008
116
I also had one fail on a 2006 Nova, this was in 2008. I checked the wiring diagram and there was a small fuse on the board inside the case, so I opened it up and replaced the fuse. On testing there was a huge bang as the board exploded! I therefore put the original blown fuse back in, resealed the case, and told the supplying dealer that it had appeared to fail, and they changed the whole thing FOC.
The OVP device might be a good idea though, anyone any idea where to get it from?
Pete
Apr 7, 2008
4,909
Pete
I got this off a motorhome web page..
This is the man to contact about the OVP 01 for the hymer charger
Udo.Lang@schaudt-gmbh.de
They accept Paypal & his english is good from what i have read
OVP 01 orderNo /part No ( 999.193 )
http://www.schaudt-gmbh.de/uploads/media/Schaudt07_GB.pdf
http://www.motorhomefacts.com/modules.php?name=Forums&file=viewtopic&p=705711
I wonder if other manufacture's are having the same problem but it's not being highlighted ??
Do I buy one ? I can't see us going abroad ??
Apr 14, 2008
116
Thanks for the info - I will look into it.
We go abroad a lot, but only within the EU. Having said that though I think wiring could be dodgy anywhere if you are out of luck.
Pete
I have just been reading about these & the web site say's....
Risk of overvoltage is particulary high, e.g. mains operation when travelling abroad, especially in non-EU countries.....
http://www.schaudt-gmbh.de/uploads/media/NL20060804_-_OVP_01_EN.pdf
Hymerman
were you in the uk when your charger blew ? or abroad ?
On a CL in this country and with the first it would have been in the UK
What puzzles me as to why Hymer does not fit this OVP devise or advise that one should be fitted.
3,907
1,649
Pete
Email Udo Lang at Schuadt Technical support.
email: udo.lang@schaudt-gmbh.de
Udo Lang, technical support
Schaudt GmbH Elektrotechnik & Apparatebau
Planckstr. 8 - 88677 Markdorf - Germany
Tel. +49 7544 9577-70 Fax +49 - 7544 - 9577-29
Dec 21, 2014
Hello, I know this is an old thread but it keeps coming up in searches on issues with the Schaudt Elecktroblock units like the CSV409 fitted to the Hymers.
We repair them, and 99.9 times out of 100 they are damaged by a battery past their best, not any other problem.
I know the forums are full of stories of mains 240v Mains issues but it is incorrect. We have now repaired thousands of chargers from all Caravan/Motorhome Manufacturers and they all, including the Schaudt chargers, use similar components/technology for inbuilt Spike/Surge protection.
The OVP 01 is not a Spike/Surge protector it is a Over Voltage Protector that cuts power to the protected device if the Mains input voltage goes outside preset limits. It is a relatively slow acting unit that will let through the majority of Spikes/Surges. It is designed to trap slow rising voltage changes, such as those from a spluttering Generator. See our OVP01 website page and read the Schaudt manual. You will see it makes no claims in respect of Spikes/Surges.
It is tired batteries that are the culprit for the majority of charger failures, see our Battery Charger Faults page for how to extend the life on ALL Caravan/Motorhome charger units. http://www.aandncaravanservices.co.uk/battery-charging-faults.php
Battery quality and youthfulness is the key, as now being recognised by experts across all the Forums.
We are Schaudt recognised distributors (as well as Nordelettronica and Arsilicii, etc) so know a little bit about the boxes.
