I have just been on holiday in Devon using my new toy. It is a navigation aid called SMARTnav. It is GPS guided and it is live 24/7 x 365. You push a button and it calls the Control Centre; An operator asks you where you would like to go, you give them the information you have to hand: ie the name, the location, or the post code. It then downloads the route to you live for the whole of your journey. If it encounters any hold ups or accidents on your route it will tell you that it is about to re-route you to avoid any delays. Then when you are past the obstruction it will put you back on to your origional route.
If you are towing and it sends you on a B road ignore it and it will keep re-routing you till you are happy with the A road that you are on.
Whilst on your journey should you need to make a stop, or de-tour to a garage, or bank, or supermarket. Just press a button and ask the relevant request and it will do it for you. It is not like the ones available in the high street which are pre-programmed, ie CD ROM driven from the boot or where ever it is stowed. This one has the facility to inform you of active fixed cameras: TREVELO/ SPECS (variable speed cameras) and whatever the Blue ones are called.
We had a map in the car which we used to see where we wanted to go and let SMARnav do the rest. Best thing I have bought in a very long time.
David L
David L
