I've got a Brink diagonal detachable towbar on my 2014 S-Max, was fitted when I bought the car 2.5 years ago. The last time I went to fit it, it took several attempts to get the mechanism to engage properly but a bit of wiggling and in it went.
After a week of driving around with it on, I went to remove it .... no luck, the dial would push in and turn but could not feel it releasing the catch. After several attempts at this, much wiggling and a gentle caress with a rubber mallet I unbolted the receiving part of the mechanism from the car, removed, sprayed liberally with WD40 and left for 24 hours but it's still stuck fast. I live several hours away from the garage where I bought the towbar, and the only Brink fitter in my area is only open Mon-Fri 8:30 to 4:30 i.e. when I'm at work.
Anyone ever successfully repaired one of these before? I've had a look on Ebay and you can buy replacement dials (i.e. the bit you push in and turn to release the bar from the car), so presumably you must be able to remove the one that's on there - but can't see how at all!
