Isabella Venture Minor Porch Awning excellent condition
2,541
At present we are using a Quest Falcon 325 but been looking at other porch awnings on site anywhere seen the above item come up and it comes with CarbonX poles and fixOn II bracket pads , including extras and it be easier access for my mobility scooter .
There are plenty on site have air and poled porch awnings.
5,175
BB have you discounted the bigger brother Izzy? The Magnum W 340 cm x D 250cm. Just as easy to erect. Mine has the carbon x poles, all four doors remove making for an easy erection😉.
Got mine used off Gumtree years ago.
You may find the extra width and depth make it easier for your buggy.
Plus if you also use the Izzy or similar storm straps and pegs I’d be happy leaving it up all year round.
I can’t remember what you said previously. Are you permanent or semi permanent where the site also hitch and pitch for you using their storage?
Oct 21, 2020
386
233
4,935
We have the Minor awning, perfect size for us.
Poles are very lightweight and easy to use, fabric is light and packs away quite small.
Reactions: Beachball
2,541
We are permanent seasonal from 1st March to 31st October with winter storage on pitch or using the storage compound . might have a look at the suggestion but she likes the minor .
Oct 21, 2020
386
233
4,935
We bought an additional veranda pole for ours, it allows us to open the front and have it half way open in height but supported (if that makes sense)
Great awning
5,175
I was really thinking about the room the buggy will take and if you guys fancied an alfresco meal.
2,158
My thought would be, if you are putting up an awning that is going to be left up all season then a bigger one is no different in effort to a smaller one. So why not go for the extra space. More room for you, buggy and dog.
Up to you ( or Mrs BB) of course.
172
95
635
We used to have an Isabella Minor lovely awning, however the mobility scooter took up some space it was a little bit tight on space, there was definitely no room for a table and chairs to eat in the awning, so we sold it.
We purchased a secondhand Isabella Magnum 250 awning as easy to erect as the Minor, considerably more space enough for the table and chair as well as the mobility scooter.
2,541
I would love one just a bit bigger seen a Dorema Mistral but the Isabella Magnum might have the edge but my wife does not want one to big so a full awning has been ruled out .
5,175
BB
The Isabella Magnum is a “porch “ awning, not full size. How long is your caravan?
You have already said what you need it for. The smaller ones imo would disappoint you both.
My Magnum is about 40% the length of my Wyoming.
2,541
BB
The internal length is 20ft and shipping length 24ft 9ins so i think it will fit (y)
Oct 11, 2023
172
95
635
We had both a full Isabella 900cm and Isabella Magnum awning, it is just as easy to erect the full awning as a porch awning especially when you include those rear poles the only difference is the pegging out. As we no longer take my mobility scooter we have sold the Magnum and decided to go back to a Isabella Minor, for short breaks apart from the pegging out it is easier to dry at home if it gets wet.
From experience with a mobility scooter and 2 small dog there is little to chose between a full or Magnum porch awning, a full awning is more weather tight and stable in stormy weather than a porch awning.
Reactions: Dustydog and RogerL
2,541
That what you prefer a full awning that your choice but at present we have a 325 with rear supports poles and a roof pole , but we will only be looking at either a Isabella or Dorema but no more than 340 .
On this seasonal site there is a lot with porch awnings especially Dorema Mistral all season .
Oct 11, 2023
172
95
635
If the wife likes the Minor I would go with it, I have seen several Ventura Minor awnings on eBay for around £250, Ventura is owned by Isabella, does not have the Isabella badge plus uses a slight lighter grade fabric, they are good value and every bit as good as the Isabella and slightly lighter.
2,541
We saw one advertise when we were down at our caravan sent a email it suppose to have everything and in excellent condition but as we were on way to see it , we got a phone call and the seller said he could not find the curtains and rear poles and we declined, but we have not ruled it out .
5,175
Latest news we manage to pick up a Isabella Magnum Coal 250 porch awning comes with carbon x frame full set of matching curtains, draught skirt and awning skirt Isabella storm straps and pegs he has labelled all poles and extras . Just one thing are they easy to put up .
Well done BB👏👏
Hope the price was good.
You should be able to pull,the awning through the rail easily. You can use silicon spray as a lubricant.
Take the centre roof pole , the centre upright and the centre upper short pole that goes under the external canopy.
Using one of the Isofix brackets clipped onto the inner Kador exactly where you want the centre of the awning. The hook on the pole end clips into the Isofix. You almost have to hold the pole vertical and then insert and bring up,to the horizontal. Up goes the upright , pass through the short piece into the small canopy fringe making sure the upper eye on the pole joints goes through the awning roof eyelet. Mrs BB only needs to keep the upright vertical for a few seconds as you attach the two front rails and two sides etc etc.
Best look at This
8,872
We found our Magnum to be more useful than a full size awning even for four people and two dogs. Plus no change required if you change caravan.
Oct 21, 2020
386
233
4,935
We are away at present and have the minor up, it took me 20mins to erect it. Tip I can offer is to put the 2 front uprights in place and get some lines on them, after that it’s just slotting a few poles in and pegging down with screw in pegs.
2,541
Well done BB👏👏
Best look at This
Thanks for the video he makes it look easy the seller who sold it they are retiring and he had it cleaned and coated with Aquatex since new and it looks stunning the price was in our budget . we go to the seasonal site in sepember and have arranged collection on same day we will be using it next season it will be stored in the loft at our bungalow
2,541
Thanks for tip going to to look at pegs where we are at our seasonal site I put these in with our present awning Blue Diamond hard ground pro and some 8x 12in heavy duty steel ground pegs .
5,175
Note the storm straps on the Izzy attach to the upper side poles near the end downs. You won’t be disappointed.
2,586
Beach ball, hope you checked on the window and locker locations will not interfere with the awning length. But I do believe that the Izzy 340 is a much better option.
Like you, I am looking for a porch for our seasonal site. Lots of Izzy 340’s around, most look good. But I wanted the 400. As I always think, ‘in for a penny’. There are far less 400’s around.
I also looked at the Isabella Cirrus North 400. One has just become available and just been reduced by a few hundred. I go to see it tomorrow. So fingers crossed.
1,190
771
1,435
Tip, if buying pegs, get the ones that drive in with a drill, I invested in some and they are great. They weren't expensive from go outdoors.
