Isabella Venture Minor Porch Awning excellent condition
8,878
Reactions: Beachball
3,950
1,692
Viewing them, would they not be difficult to drive in, at least with a lump hammer, simply because you can't strike them in line with their shanks?
8,878
I never had a problem driving them into a the ground on a pitch. The only problem I have with reinforcing bar is emotional, as I lost a part of my right thumb to a bar as a guillotine came down in Cardiff GKN steelworks where I was working on production shifts. Ruined my bonus for that days shift!!!!
5,182
Don’t forget things like rebar may have sharp ends which in the wind may cause damage to the canvas and loops. For decades the screwpegs have served us well. Both the oem s and the Screwfix ones described by Buckman. The originals have sharpless tops that hook onto the canvas securing bands. No chance of damage in the wind.
Installation for years has been the hammer. Removal the claw hammer nail extractor.
Looking at the rebar is it easy to pull out of the ground🤔
8,878
Yes no problem removing them using good quality claw hammer. Wrt your comments I would use them on storm straps, and/or just at the corners of an awning in periods where bad weather was forecast. Sometimes would use them with extra guys on the awning. I first bought some when the standard awning pegs even with storm straps and guys just would not safely hold the awning at Freshwater East. CMHC. The hard pitches were sodden and composed of very fine aggregate/sand. After a sleepless night during a storm holding down the awning I went out to buy the J pegs. Normally though I’d use ordinary rock pegs with a spiral scroll down their length. I was never aware of the long J pegs made from reinforcing bar doing any damage to the awning or its loops. But you can get smooth variants too.
2,541
Not long ago i posted a photo of some super long J pegs made out of steel spiral reinforcing bar. I’ve used similar and from my experience they hold anywhere, even very fine soil/sand pitches.
Yes brought some of those for my present awning just hoping I can get them out of the ground as we are taking it down next visit to the site
8,878
Just grit your teeth, as Mrs Beachball gets to work on removing them. 😂
5,117
We had four of these for the corners of the awning just in case of a storm. We also used them for our sun canopy. No way are they going to shift.
2,541
We are about to be erecting an awning on a seasonal pitch, it will potentially be staying up for 9 months, we are not allowed to use the grass. So hopefully these will do the job.
They look good quality. and easy removal ,and they should do the job
5,182
You can buy J pegs similar to rebar ones, but which are smooth, thus addressing one of your concerns. The Towsure link in #34 gives details.
That are smooth surfaced.
The screwpegs with their serrated surface probably add more resistance in bad weather.
The Isabella storm pegs are long but L shaped adding to security in the ground.
As we are interested in seasonals the pmut be strong and robust enough to remain fastened in the ground no matter what.🤞
5,117
The J pegs can also be serrated offering better grip. Our Isabella L shape storm pegs were only used on the inside of the awning as the strap goes over the corners so hard to angle them into the ground.
5,182
I must say I’ve never had any problems with my Izzy storm pegs. Dare I ask if you bend over or kneel down🙉😁
5,117
They have never been a problem as they are quite long and stood firm in high winds. If I bend over I will probably be airing my views! :LOL:
  • Haha
8,878
My Magnum had a set of additional tie down points low down on the outside faces. Very effective but a bit of a bind to set up. Think they may not be fitted these days. See post #11 in the link below
