Jockey wheel
Status
Not open for further replies.
Sep 21, 2022
55
9
1,585
Not wishing to highjack this thread in any way I also have concerns that my jockey wheel and its assembly, I inherited this on my van which is Bailey Unicorn 2018, it's an Alko and I think likely the original aparatatus.
Do they have a date by which they should be replaced?
I quite fancy one of the Kartt systems I'm assuming mine is a 48m would it be ok to use the original Alko clamp?
Jun 16, 2010
386
169
18,735
They only need replacing when they break !
But
The Karrt Ultimate is a huge improvement over the standard one, and is a straight swap.
Reactions: Pamplona
5,165
But
The Karrt premium is a huge improvement over the standard one, and is a straight swap.
In what way is it a huge improvement over the standard one as surely a jockey wheel is a jockey wheel? :unsure:
Jun 16, 2010
386
169
18,735
Subjective, but for me
The wheel is wider and taller, so runs better over grass and gravel. Also runs over my dropped kerb more easily, the Alko one would get hung up on it.
The quality of construction is better, the handle can't wind down due to vibration and the handle itself is much more comfortable to use.
Initially, i only swapped as the Al-ko one provided by Swift was too short to get the caravan level without using blocks !
5,165
Thanks. The rubber on our wheel has seen better days, but is still operational as the rim is metal and not plastic. Does the Kartt have a metal rim with rubber tyre?
Never had an issue with this jockey assembly unwinding, but had it on a previous caravan. Is there a reason why it can't wind down while in transit?
Can we assume that the unit splits in tow like the ALKO and that no modification is required to the jockey wheel shaft clamp?
Sorry for all the questions, but good to get answers from someone that is using one. (y):D
Jan 19, 2002
1,705
546
I expect that Pamplona is aware that you can purchase replacement wheels. I have just done this as the track surface was almost worn away - and to my surprise when I removed it I found one of the 'spokes' in the centre section cracked too. The original was likely to be BPW and although I measured carefully to replicate as close as possible I did need a couple of shims to ensure the new sat centrally in the fork, along with a new split pin and now ready to roll! One of this ilk:
OIP.9NceS1OOLNHxvbKnc19x-QHaFj
5,165
This is our current jockey wheel and I cannot find a direct replacement for it as it has the metal rim. Most seem to have a plastic rim which cna crack after a few uses. Although it is an ALKO chassis, the jockey wheel assembly may be a BPW assembly?
8,955
Not a very good fitment for a caravan with such a high noseload. Probably use the same fitment across all, or many, models.
Jun 16, 2010
386
169
18,735
That's right, it's a metal rim with rubber tyre. It splits in two, just like the Al-ko one does and is a direct replacement (no modification required)
It appears to have a ratchet type mechanism to prevent it unwinding. Not something I came across on my last few units , but my sister in laws jockey wheel did it all the time. In fact, i gave her my old one to try and stop it
Plus, it's bright orange, and who wouldn't want that !
5,165
Not sure I understand your remark regarding it not being a good fitment for our caravan? :unsure:
Jan 19, 2002
1,705
546
I searched google images and although you would need to check sizes is this the sort of thing you need?
8,955
There was a thread a couple of weeks ago where the OP reported that the OEM jockey wheel had a tendency to unscrew.
5,165
Looked at them on CAMC and the ribbed one is nearly £100 before postage. Even with member's discount still very expensive when you add on the delivery charge of £6.80. Amazingly the CAMC website is identical to the Prima Leisure shop?
Maybe other places are selling them at a more competitive price. I will need to Google search.
Jun 16, 2010
386
169
18,735
I found mine on ebay, which was much cheaper
Sep 21, 2022
55
9
1,585
I am getting confused here, are we saying the orange plastic wheels shown on the the Kartt advert and also in the post above are no good? I have zero experience with plastic wheels. I was thinking of replacing it as I thought mine looked worn out. I was not suggesting just the wheel replacement but the complete unit.
5,165
Going back to post #3 I think that the Kartt non slip would be best as we use a lot of CLs and the fact that the wheel itself is a lot wider than the standard ALKO wheel has swayed me so instead of replacing the tyre we will go the whole hog! :D
Reactions: Pamplona
5,165
145kg on a wheel that width surely digs in on some gravel pitches or soft CLs.
I would agree with you, but I cannot recall coming across that issue yet. I guess it could be that my reversing skills are so good as no need to use the mover when on a CL. LOL! :D
Seriously though I try and be a bit macho and put my driving skills to the test and put caravan onto a pitch with the least amount of damage to the grass. A bit of fun for me.
Having said that I cannot remember when last I used the mover even to squeeze the caravan between two others at our storage. OH is very good at directing me. (y):D
2,596
I have made my point of view before, but in my opinion, a puncture proof pneumatic tyre is the superior option. Once tried, you would not go back.
However, a search was done previously, and one could not be found to suit a TA’s nose weight.
5,165
Nope that was probably me. Using the mover the tyre came off the rim. It seems that we wee not the only ones that had this problem with the pneumatic due to nose weight being well over 100kg on the TA. :D
Reactions: Pamplona
5,250
You need to know the OEM SPEC before looking at pictures with no spec!
Here‘s a pic of my Senator oem . It’s big and heavy. Designed by Al-Ko to match their chassis, which in turn is chosen by caravan manufacturers for each model . So mine is 240x70 rigid plastic wheel,quite a wide tread
I‘ve replaced with new recently. Why buy something that may have a lesser spec than your oem? Going better is fine of course!
2,596
There are some rubbish pneumatics, not fit for wheelbarrows, but, even with the good ones, max load was. 105kg from memory.
5,250
I’ve had pneumatic before, no good. Punctures easily, lose pressure quickly due to small size , just something else to go wrong. The pic I showed lasted 15 years and is still operational over many rough terrains. Dare I say , don’t reinvent the wheel😜
Sam Vimes
2,509
2,011
12,935
Changed my wheel a couple of years back. Hopefully the above link gets to the right post.
Reactions: WayneS
Status
