Kampa Air Awning rubber valve pipes repair suggestions
Jun 25, 2025
I’m going to have another go at trying to repair the rubber valve pipes attached to the air bladders, which have some small cracks in them that air is escaping slowly from.
I’ve tried in the past and got a couple more to fix.
All the posts I find are for repairing puncture to the bladder skin, not the rubber valve pipes. I’ve replaced the valves to eventually find the cracks on the pipes.
Has anyone had this themselves and managed to successfully repair than replace the entire arm(s)?
This was the next product I was going to try https://amzn.eu/d/dGuxdSV
Any suggestions would be appreciated thanks
Jun 11, 2012
1,531
31
19,685
Is this a Kampa Awning? If so the valves are or were common problem When Kamp first came about I had to have lots of new tubes as there was manufacturing issues with these Valves . Begs the question how old is your awning ?
1,531
31
19,685
Another addition to the " I hope I don't need it Toolkit"
As per my previous answer to your inflation tubes As I said I had several replacemet tubes inner and inflation. It was a common fault with the early Kampa inflatables. Mine was the very first Kampa Inflatable to be sold .Kampa themselves were good about helping with the issue. I was being supplied with replacements that they were not supposed to be sending out Kampa in the End sent me a comlete set of new tubes with the inflation tubes .They had to restucture the whole business because of
