kojack jacking brackets
Feb 13, 2024
1,574
1,006
2,935
if i buy a set of kojack brackets for the van, do i need to buy there jack? i carry a halfords bottle jack, will that fit/do?
Apr 23, 2024
663
527
1,135
The little brackets which fit onto the trailer have a round bar on them , the Kojack jack has a mating round 'hollow' ( see photo) this allows the two parts to 'lock' together. A 'normal' bottle jack doesn't but has a serrated flat surface , so may slip off the bracket ( particularly if not on the level). your choice
Reactions: RogerL
Feb 13, 2024
1,574
1,006
2,935
Thanks for that Ian, I thought as much. Being a tight Scot I thought i would get away with just buying the brackets. Better to be safe then sorry. (y)
Sep 4, 2011
778
481
19,135
If you are already carrying a Bottle Jack then just place it under the reinforced bracket where the axle fixes to the chassis.
4,816
Here is the Kojack bracket, it is the same as the Alko heavy duty one. One point is that you real need the van to be as close to level by raising the nose on the jockey wheel to get a safe lift.
2,367
Thought you were van shopping? If so don’t waste money on new brackets.
4,221
1,939
Which seems to preclude the caravan being on the tow car's hook, which is IMO itself a massive plus re jacking up a caravan "safely", the more so if only jacking with a direct lift jack.
I am firmly a user of the tow car for this and for using it to haul the stricken wheel up on any suitable blocks, ramp etc to get it as level as possible and sometimes to even place the jack correctly.
