kojack jacking brackets
Feb 13, 2024
1,576
1,010
2,935
if i buy a set of kojack brackets for the van, do i need to buy there jack? i carry a halfords bottle jack, will that fit/do?
Apr 23, 2024
663
527
1,135
The little brackets which fit onto the trailer have a round bar on them , the Kojack jack has a mating round 'hollow' ( see photo) this allows the two parts to 'lock' together. A 'normal' bottle jack doesn't but has a serrated flat surface , so may slip off the bracket ( particularly if not on the level). your choice
Reactions: RogerL
Feb 13, 2024
1,576
1,010
2,935
Thanks for that Ian, I thought as much. Being a tight Scot I thought i would get away with just buying the brackets. Better to be safe then sorry. (y)
Sep 4, 2011
778
481
19,135
If you are already carrying a Bottle Jack then just place it under the reinforced bracket where the axle fixes to the chassis.
4,818
Here is the Kojack bracket, it is the same as the Alko heavy duty one. One point is that you real need the van to be as close to level by raising the nose on the jockey wheel to get a safe lift.
2,373
Thought you were van shopping? If so don’t waste money on new brackets.
4,221
1,939
Which seems to preclude the caravan being on the tow car's hook, which is IMO itself a massive plus re jacking up a caravan "safely", the more so if only jacking with a direct lift jack.
I am firmly a user of the tow car for this and for using it to haul the stricken wheel up on any suitable blocks, ramp etc to get it as level as possible and sometimes to even place the jack correctly.
4,818
You can still raise the nose with the car attached to the van, if the nose of the van is low , you will not get a safe lift using the Alko or Kojack jack points. I fully agree about raising the flat wheel by using ramps.
Feb 13, 2024
1,576
1,010
2,935
Well I've just bought a kojack from the bay of plenty, as I have been flogging a lot of fishing gear on there, my balance was healthy. Regarding change of van, just booked a service for my Lunar at end of march, will wait and see what that throws up. Happy days 😉
2,683
Did you get a good price for fishing gear on there , ;)
5,565
Strangely Hutch my 15 year old Kojack brackets are different, triangular compared to my original Al-ko which as you know failed dangerously. The oems were straight brackets that when under load collapsed and bent through 90degs. At the time Kojack brought out their triangular heavy duty brackets which for me have worked safely with no issues.
The following photos are like mine. I can’t find now the originals of the Al-ko failures.
9,632
Weren’t the ones that failed L shaped 1000 kg. These have been replaced by triangular 1000 kg brackets. But the 800 kg ones are still L shaped., although both types share the same fastening holes why buy the L shaped when a triangular 1000 kg is superior.
Reactions: JTQ and Hutch
5,565
No . They were dead straight and bent L shaped when they failed. I posted photos years ago but can’t find them today.
9,632
Cannot link to the pictures but found your old posts wrt the failure. The brackets fitted were marginal at 800 kg on your caravans weight.
