leaking shower mixer tap
Aug 4, 2009
98
please help? i have a abbey gts vogue 215 (2002) and the whale shower mixer tap is leaking, its leaking from where the hot and cold (blue and red) inserts go into the bottom of the tap itself, not the water pipes or the 12mm push on connector, as you cannot buy the 2 inserts i am toying with the idea of super glueing them in and if this doesn't stop it i will have to buy a new mixer tap, i think they are 27 pounds new, does anyone else have any suggestions? regards mark.
SBS
Mar 15, 2007
210
The inlet pipes are a push fit fith a plastic pin to hold them in. I think there are a couple of O-rings to seal them. It may be possible to replace the O-rings.
Mike
Aug 4, 2009
98
1st thing i tryed SBS. just super glued them and the cold is ok, hots still leaking, i will put more on the hot and see how it goes. got nowt to lose realy, will let you know how its gone later
