At the moment we use the yellow levelling ramps, but as we have the ALKO lock it can be a PITA. A few people have mentioned that they use wooden planks as they can raise the caravan plus you can move the caravan to the correct position so that you can line up the receiver. The drawback with wooden planks is their weight plus they get dirty easily.
However as you can now buy plastic planks which are normally used for outside decking, I thought that this may be a better proposition as they should be lighter with flexibility. They come in three sizes;
- 18mm x 140mm x 3m/3.6m black and brown: very flexible
- 24mm x 140mm x 3m brown: quite a high degree of flexibility
- 38mm x 140mm x 3m / 3.6m brown with a rough surface: less flexible
