Light squeak on braking
Jun 16, 2023
91
33
585
Hi all,
Quite often I hear a slight squeaking sound coming from the caravan when braking. The caravan have had a full service a month ago without any issues.
Sometimes I think it's not the breaks but something from the hitch as there is no sound on repeated breaking (so the overrun dumper has not released back).
What should I do?...
Nov 30, 2022
1,787
1,631
2,935
Brake squeal is a very common issue with Alko brakes and is experienced by many caravanners. There is nothing you can do about it other than replace the brake shoes and drums (very expensive option) It's NOT safety related in any way at all, so it's safe to ignore it.
Noises from the hitch are creaking sounds when turning. So if this noise is when you are in a straight line then it's brake squeal, it usually happens just as you are coming to rest.
As Kevin has said, turn the radio up.
4,053
Hi all,
What do you think you should do?
You are obviously concerned enough to ask a question in the forum, but with teh best will in the world, we cannot see or hear the noise, and thus all we can do is speculate about what it might be, and we could be wrong.
I disagree with the answers you have been given which suggest ignoring it. You want an answer, and the only practical way you will have confidence about it, is if its been checked by someone who knows (i.e. a caravan technician) who has physically been able to check it.
From your description it does suggest its hitch related and it could be the overrun brake sticking which is something that needs to be corrected other wise it puts extra load on the tow vehicle's brakes and critically it will impair braking performance.
Sep 4, 2011
366
162
18,735
This has been going on with Alko chassis and brakes for some time. There was a statement by Alko that they would do nothing about it as it did not affect the braking efficiency and was due to the brake lining material having to be used since Asbestos in the manufacture was banned. This was thoroughly discussed back in the days of Swift Talk.
Jun 16, 2023
91
33
585
Well it had been dealer serviced a month ago with the squeak present so I assume they'd have flagged any concerns if there had been any?..
