Looking for thermocouples for 1990's gas hob/grill
Jul 28, 2025
17
6
Hi all - we have a new (to us) 1990 Cotswold Windrush 132, with a (as best we can tell) Cramer combination 4-burner gas hob and grill.
The service identified the thermocouples aren't behaving as they should and need replacing. But this is a 1990 van - the internet does not help here identifying the exact brand and model.
Any help identifying this hob, or the thermocouple that would fit it would be hugely appreciated. or a replacement hob or hob/grill that measures 470 x 380mm!
Apr 19, 2023
227
157
1,635
Jul 28, 2025
17
6
On gumtree
Thanks - problem is all the caravan places I've rung say they don't touch used parts. Is this common?
Apr 19, 2023
227
157
1,635
A main dealer is not going to fit a second hand part. Given the age of your van I doubt you will get new parts. You'd need to find a gas fitter or caravan engineer on line who is prepared to fit a second hand part. They won't warranty it but not sure you will find another way of getting a fixed.
Apr 23, 2024
373
301
935
I have not come across a faulty thermocouple on a gas hob( they are type S and made from Platinum/rhodium ), they are quite robust, but I have come across lots of hobs with faulty connections from the thermocouple to the gas valve . A good engineer will check the thermocouples for a good output( about 17 -26mV at 600 Deg C) when hot before writing them off and the gas valve solenoid can be checked with a small AAA battery with a couple of wires soldered on . Often, where the thermocouple connects to the gas valve can become loose or oxidised , removing the end of the thermocouple and cleaning it up can often rectify the fault.
2,138
Are you in the UK, Kiwimike? There are breakers in the UK such as SFM, Premier Towing Centre, and KTG. A mobile tech may fit a used part, as Andy says.
5,132
DOMETIC CRAMER THERMOCOUPLE COOKER SPARE 407144290 CARAVAN & MOTORHOME​
Jacksons Leisure Supplies
(62975)
BusinessRegistered as business seller
99.6% positive
Seller's other itemsSeller's other items
Contact seller
£1,044.95
£97.75/month for 12 months at 21.9% APR with Klarna
18+, TC apply, Credit subject to status.
Condition:
NewNew
Quantity:
Last one7 sold
Must be a mistake on the price! Doubt it is yours. But it seems Dometic took over Cramer. May be worth asking Dometic if they have any Spares hidden away somewhere.
8,838
(62975)
99.6% positive
Contact seller
£1,044.95
Condition:
NewNew
Quantity:
Last one7 sold
I’ve found that where a stupidly high price is quoted the items are stock out or unavailable.
