Nov 30, 2025
Hi all
New to the site and camping
Have bought a Ellis’s Wisp CT 450 and it’s in great condition but no door key and have checked for codes and all I can read is WD which I have found but can’t find and 3 digit
Codes
Apr 23, 2024
569
461
1,135
You may have to replace the barrel complete with new keys. You can buy five barrels with two keys for about £30 off ebay https://www.ebay.co.uk/itm/383782644789
If the lock is open then you can buy a barrel removal tool which releases the last guard on the barrel and it will pull out ( see photo with red arrow showing the last guard), once you have also removed the 'arm ' on the back which does the locking and this accessed from the back of the door. and by the way its an Elddis caravan. My advice to get the barrel out and check what's on the back as on Some caravan doors , such as Swift have a long 'tang' at the back others have square sections to which a cam is attached with a short screw A and L leisure also stock WD west alloy locks and keys, however the code for the lock is on the key ( obviously) so without a key you will need a new barrel.
2,620
Hi Laoisexplorers welcome to forum sorry I cannot but I think you will receive all the help and advice how to get new keys for your caravan .
Apr 23, 2024
569
461
1,135
I have one of those barrel extractors tools birdman posted , never figured out how to use it, also have a Vecam key ( https://www.ebay.co.uk/itm/392706658248) for depressing the last lever which holds the barrel within the lock , even in the open position , unfortunately its not long enough to work the barrels with 6 normal levers.
