LPG in France
Feb 19, 2006
158
Hi Andy
Yes, most garages seem to have it they call it GPL however you will probably need an adapter you can pick them up on ebay or you local lpg garage that does conversions will probably be able to get hold of one for you. Hope this helps. Simon
Nov 1, 2005
1,001
The adaptor you'll need is called a dutch connector, most of the larger garages will have one which you can borrow if you can speak a bit of french.
Apr 12, 2005
34
Hi Andy,
I found the adaptors a lot cheaper to buy over in France from the actual service stations or if they don't sell them most will lend you one.
As someone has already said there is one called a Dutch connector but there is also another type they use which was more common where you screw the bayonet onto the fitting (it's like a large threaded adaptor)this one i came across a lot while travelling down to Luxembourg.
Hope this helps Paul
