LPG in France
YES.
Even many hypermarkets sell it if you mean for your car!
But you may not be able to get the caravan out the exit pay booth chicanes!
Hi Andy
Yes, most garages seem to have it they call it GPL however you will probably need an adapter you can pick them up on ebay or you local lpg garage that does conversions will probably be able to get hold of one for you. Hope this helps. Simon
The adaptor you'll need is called a dutch connector, most of the larger garages will have one which you can borrow if you can speak a bit of french.
Hi Andy,
I found the adaptors a lot cheaper to buy over in France from the actual service stations or if they don't sell them most will lend you one.
As someone has already said there is one called a Dutch connector but there is also another type they use which was more common where you screw the bayonet onto the fitting (it's like a large threaded adaptor)this one i came across a lot while travelling down to Luxembourg.
Hope this helps Paul
