Lunar Clubman SI 2018
2,230
that part is ok but I need to get behind the lights to fit the camera also
That may not be possible - I suspect the visible ABS moulded rear panel is mounted directly against a conventional aluminium/foam/ply bonded sandwich with no way of accessing the void in between.
It may well be necessary to surface-mount the camera with the wiring visible.
