Microwave
Aug 6, 2016
26
4,535
I own a 2013 Sprite alpine two berth, and looking for a microwave for it can anyone put any light on which ones are available and has anyone had one fitted to this model as space is limited in the overhead locker, my own caravan dealer in nothing short of useless, thanks,
937
As you say space is limited, you need to measure what you have available, then find a suitably sized microwave to fit.
4,741
Hello Nimrod, welcom to the forum, many people have changed their failed Microwaves, for new ones and they are normally the lower powered ones , srtaight from that big "Cuury shop, "that just fit into the empty hole.
If your fitting a new one you have to make sure that the ventilation system around the microwave is adequate and the power supply point is also suitable.
I hope others can help on the more technical points.
Hutch.
Nov 6, 2006
731
5
18,885
There's a YouTube video of your van, and it looks as though one of the two larger kitchen cupboards should accept a MW. You will need to consider how to restrain it on the move. Swift use an inverted u shape bracket the width of the MW with two holes at the front to locate the front feet of the MW. A 6mm plate slides into 2 channels from the front across the top of the MW to stop it jumping about. There is an air gap around the sides, bottom and top and to hide all this there is a plastic trim around the MW front. If you can have a look at an installation
Jul 15, 2008
3,926
1,115
Welcome to the forum.
Most caravan builders break that well known loading rule of not putting heavy weights in high cupboards :whistle:
Why not just buy a microwave to suit and have it free standing.......that is what I do and it is transported in the tow car and so does not use up caravan payload.
May not apply to you but I go off grid quite often so then the microwave can be left at home and is not carried unnecessarily.
4,459
Most caravan builders break that well known loading rule of not putting heavy weights in high cupboards .
Just like towing ratio not a rule just a guideline. :p
Jul 15, 2008
3,926
1,115
......I chose the wording just for you Prof just to see if you picked me up on it. ;)
In my tiny world both are rules :p
40
If you go abroad or use sites with limited electrical supply be careful about the power requirements of any microwave you buy.
The stated power is the running power but MW usuall take a good deal more than this short term on start up. This can easily trip site breakers.
Find out the power ratings of MW fitted to caravans and stick with this.
Ovens having grills or browning elemenyts are likely to have much higher reqirements than basic models
As a very crude example a 1000 watt appliance on 220 volts will take 4.5 amps steady state, but your fridge will probably be taking a some as well together with the charger in the caravan. the peak inrush current may well trip a nominal 6 amp continental supply.
Mar 10, 2006
3,274
47
Personally I wouldn't bother fitting one.
They are not designed to fit inside a cupboard unless they are a built in appliance costing lots of cash, they need a lot of ventilation otherwise.
Also they weigh a lot, probably 30 pounds at a guess, I took mine out of the last caravan because it would sometimes trip the bollard, despite having it replaced the new one did the same.
Even allowing for the current consumption it would trip, which was at least 1200watts from memory, so not very efficient.
Mar 2, 2010
1,231
6
19,185
We replaced ours with a digital Daewoo from Makro saw the same in Asda for £50
Bailey used a piece of wood self tapping screwd to the base and then screwed to cabinet its been fine.
Jun 17, 2011
826
27
18,885
Firstly watch the payload as they are heavy and might just put you over the limit. (The VOSA people are reportedly checking vans.) We have one in our Coachman which I use when we are on a hook up but watch what else is on before starting it. Ours is fixed high up as usual with a lip restraining the feet and a piece of wood on top stopping it lifting. This is fixed in place with 2 spring clips so easily removed. You may need to check the depth to ensure the door still closes.
Jun 2, 2017
141
yeezy boost 350
jerseys cheap
coach outlet online
heat jerseys
phillies jerseys
cowboys jerseys
hermes bags
discount nike shoes
oakley sunglasses outlet
michael kors outlet store
louis vuitton bags
yeezy boost
mont blanc pen
michael kors outlet
adidas uk
birkenstock outlet
louboutin pas cher
nike outlet
toms
burberry outlet online
kate spade handbags
purs jerseys
adidas outlet store
cheap jerseys
toms
coach factory outlet online
cheap nike sneakers
nfl jerseys
louboutin outlet
longchamps
air max outlet
ralph lauren sale
adidas running shoes
coach handbags outlet
birkenstock shoes
coach outlet online
true religion
pandora charms
fitflop shoes
nike outlet store
ralph lauren outlet
adidas nmd r1
yeezy shoes
air max
nike outlet store
coach outlet online
michael kors
coach outlet store online clearance
hermes bag
kate spade bags
moncler uk
versace
cheap jordans for sale
prada outlet online
ralph lauren outlet online
louis vuitton factory outlet
gucci borse
mont blanc pen
swarovski sale
coach outlet online
kate spade outlet online
mulberry uk
coach purses
jordans
tory burch outlet online
adidas outlet online
giants jerseys
adidas nmd runner
gucci outlet online
adidas nmd runner
adidas outlet store
yeezy boost 350
beats by dre
rolex replica watches
nike outlet
moncler uk
gucci handbags outlet
ralph lauren sale
coach outlet store
kd shoes
cheap jordan shoes
polo ralph lauren outlet online
sac longchamp
burberry outlet store
ralph lauren outlet
kate spade outlet store
harden shoes
pandora jewelry
pandora charms sale clearance
michael kors handbags outlet
polo ralph lauren
christian louboutin
dansko outlet
texans jerseys
ralph lauren sale
fitflops
fendi bags
air max 90
dodgers jerseys
eltics jerseys
louis vuitton outlet online
longchamp bag
rolex replica watches for sale
chaussures louboutin
nike free 4.0 flyknit
rolex watches
coach outlet store
yankees jerseys
montblanc
pandora charms
fitflops sale clearance
pandora
coach outlet online
nike free run flyknit
nfl jerseys cheap
curry shoes
ray ban sunglasses outlet
christian louboutin outlet
adidas nmd runner
nike air max 95
marc jacobs
christian louboutin shoes
adidas ultra boost
ray ban sunglasses discount
cheap jordan shoes
adidas superstars
hermes outlet online
oakley sunglasses on sale
cardinals jerseys
michael kors outlet clearance
abercrombie outlet
marc jacobs outlet
hermes outlet
cheap rolex watches
pandora charms
air max 90
nike free run
nike outlet store online
longchamp handbags
yeezy boost
true religion jeans
ralph lauren sale
tory burch sale
coach outlet online
fitflops clearance
air max
cheap jordan shoes
michael kors outlet online
nike sneakers
coach outlet online
yeezy boost 350
louboutin outlet
coach outlet online
gucci outlet online
air jordans
coach outlet store
discount oakley sunglasses
moncler pas cher
polo ralph lauren
mulberry bags
sac louis vuitton pas cher
coach outlet online
ray bans
michael kors bags
adidas
toms outlet
coach outlet store
michael kors
mont blanc pens
broncos jerseys
sac louis vuitton
birkin handbags
swarovski uk
fake rolex watches
clarks shoes outlet
wireless beats headphones
salomon boots
birkenstock outlet
ralph lauren
jordan shoes
fit flops
coach outlet store
louis vuitton outlet store
adidas nmd r1
gucci
red bottom shoes for women
mulberry handbags
adidas nmd r1
christian louboutin sale
swarovski crystals
ralph lauren outlet
rangers jerseys
mulberry outlet uk
mlb jerseys
true religion jeans outlet
pandora jewelry outlet
fitflops clearance
beats wireless headphones
burberry sale
bercrombie
tods outlet
fitflop shoes
cheap nike shoes
cheap nfl jerseys
kd 8 shoes
salomon outlet
nike outlet online
burberry outlet
michael kors bags
jimmy choo shoes
ed hardy store
fred perry polo shirts
cheap oakley sunglasses
valentino outlet
pandora charms outlet
air max shoes
nike store
dolce and gabbana outlet online
yeezy boost
toms outlet
fitflops sale
michael kors outlet canada
nike roshe one
gucci
49ers jerseys
moncler jackets
mbt
michael kors
ralph lauren outlet
adidas
yeezy boost 350
nike air max
yeezy 350 boost
michael kors bags
ralph lauren
patriots jerseys
adidas nmd r1
michael kors uk
coach outlet online
nike blazer low pas cher
pandora bracelet
nike air max 95
red sox jerseys
gucci bags
coach outlet online
air jordan shoes
nike flyknit
christian louboutin
mulberry uk
moncler outlet online
levis outlet
toms
nike roshe shoes
longchamp soldes
longchamp outlet store
hollister clothing
coach outlet canada
lakers jerseys
kate spade uk
longchamp bags
michael kors
ralph lauren sale clearance uk
moncler jackets
chi flat iron
jordan shoes
hermes bags
polo ralph lauren
mulberry
ralph lauren
clarks shoes outlet
coach outlet online
nfl jerseys
coach outlet
michael kors
mlb jerseys
adidas sneakers
longchamp bags
adidas store
hollister kids
beats headphones
nike cortez classic
tigers jerseys
warriors jerseys
pandora jewelry
salomon outlet
cheap air jordans
longchamp pliage
nike air force
michael kors outlet
louis vuitton purses
michael kors
nfl jerseys wholesale
adidas superstars
packers jerseys
longchamp handbags
fitflops sale
michael kors
red bottom
pandora outlet
white sox jerseys
fitflops sale
mbt
air max
clarks
nmd adidas
cheap ray ban sunglasses
coach outlet online
adidas yeezy boost 350
burberry outlet
cavaliers jerseys
air jordans
adidas sneakers
true religion outlet online
fred perry shirts
adidas trainers
polo ralph lauren pas cher
cheap jordan shoes
pandora jewelry store
red bottom heels
eahawks jerseys
ed hardy outlet
coach outlet online
louboutin shoes
nike uk
clarks shoes for women
parada bags
longchamp sale
yeezy shoes
bulls jerseys
moncler coats
nike outlet store
vans outlet
vans store
timberland boots outle
ray ban glasses
christian louboutin pas cher
cheap jordan shoes
rolex watches
jordan retro
yeezy boost
oakley sunglasses wholesale
nike tn pas cher
jordan femmes pas cher
rockets jerseys
cheap rolex replica watches
adidas nmd runner
montblanc pens
coach outlet online
gucci bags
birkenstock uk
adidas yeezy boost
thunder jerseys
jordan uk
louboutin outlet
birkenstocks
sac longchamp
ghd straighteners sale
adidas yeezy boost
coach outlet online
fitflop
adidas yeezy boost
birkenstock
celine outlet online
air max 90
fitflop
birkenstock outlet
ed hardy clothing
nike sneakers
fit flops
louboutin shoes
ray ban sunglasses cheap
ed hardy uk
adidas trainers
ralph lauren
chaussure louboutin pas cher
ghd hair
nike air huarache
ray bans
yeezy boost 350 v2
ray ban glasses
coach outlet online
coach factory outlet store
adidas superstar trainers
michael kors
polo ralph lauren
adidas superstar shoes
mlb jerseys whgolesale
pandora charms sale
tods shoes
birkenstocks
celine handbags
yeezy shoes
red bottom
kate spade outlet
kate spade bags
mbt
fitflops sandals
mlb jerseys
coach outlet online
cheap air max
longchamp bags
dansko
adidas sneakers
michael kors uk
adidas yeezy boost
cubs jerseys
ralph lauren uk
coach outlet online
fit flops
louboutin outlet
kate spade purses
pandora charms sale
frf4t
