Milenco wheel clamp with the mover
Hello,
This wheel clamp seems to be a right pain to get on the wheel. Is it possable to get this wheel clamp on with a mover??
We have a milenco wheel clamp and a mover. The clamp goes on fine, we put the clamp on the other side of the tyre to the mover. What is the tricky bit?
mel
Think it will depend on what model of Milenco wheel clamp that you have. The other thing to look out for is that it is the correct size for the wheel if it is the version with two 'feet' that fit under the tyre.
We used the Milenco on last van with a mover and had no trouble. New van has bigger wheels so it would not fit. Can you increase the clearance between the wheel and the mover rollers as I assume that is the problem?
If you cannot sort it the Full Stop clamps look a better option. We use one of these now although bought as range of wheels it fits is far larger and it is heavier built.
