Morning condensation
Hi just wondering if anyone can help. We are away in our caravan family of 5. Our windows are always soaking on a morning and I wipe with kitchen roll and I can ring the kitchen roll out its that wet.
I look along every one else caravan and no one seems to have any condensation.
Is this normal Or does my caravan have a damp problem.
Thanks to anyone who can help alex
With five in the van it’s probably condensation. Try some more ventilation and a bit of heat at night. Five people living in the van, moisture from cooking, clothes and wet atmosphere/ground etc all conspire to create condensation as nights chill off.
If you have a damp meter a good check around will give you an indication of any damp, to put your mind at rest.
Do you leave the windows on the first catch to allow airflow. If not try it. We always leave the toilet top vent open on the first setting to give airflow as well. You do not state your caravan details so presuming it is modern with double glaze Acrillic windows
Five people in such a small space, will produce a vast amount of moisture simply from exhaling and it requires some serious ventilation in order for that moisture laden air to escape.
Heating won't do away with the issue either. Warm air can hold more moisture in suspension than cold air, BUT, when that warm moisture ladened air comes into contact with a cooler surface (your caravan windows) that moisture condenses out onto that cold surface.
The ONLY effective remedy is to seriously increase your ventilation.
Heating CAN help if blinds/curtains are closed. But it may then transfer moisture to another cold external surface. Hence the need for ventilation.
Sorry its a bailey pegasus gt65 2015 6 birth. We had our heating on all night (to hot to be honest). Only 1 window on vent in bathroom. It is our first outing this year and we had a full caravan cover on which we have got rid of as we found it held all the moisture inside. Next time we will sleep with the windows on latch.thankyou
Agreed re ventilation. But the OP needs to look at the vans fixed ventilation for any blockages. Some vans can form drafts with large vents in the floor and some will try to cover these.
Other things like lifestyle can affect the moisture load. Gas cooker, boiling saucepans, showers, wet clothes/shoes etc, damp carried through to carpets. But overall good ventilation is the key.
In one van we had condensation in a rear overhead locker as clothes touched the outer wall. So that’s something we addressed when setting up on site.
