Martin,
I have the Powr Touch fitted to my Bailey Senator Indiana, wouldn't be without it, best bit of kit I ever bought, had it fitted from new (Nov 06) by my dealer
Have you ever had to jack up your wheel? If not...I would advise you to make sure that it will do so without problems before you set off again!Hi,
I have a Reich ona Series 5 Pageant and it has been very good. R&L Draper fitted it ( use Google) and it is in front of the axle. I hav ehad no problems with ground clearance on ferries or speed bumps, and it meant that I can keep the side lift jack position and the spare wheel carrier.
Hi,Have you ever had to jack up your wheel? If not...I would advise you to make sure that it will do so without problems before you set off again!
We had our Reich fitted on to the front by the dealer when we changed our caravan and found that the wheel jammed against the mover before it was high enough to turn the wheel to check the brakes. We were glad that we were at home and not on th side of the road. We then had the reich re-fitted to the rear of the wheels as Reich recommend.
Martin,George,
Thanks for your response. Which Powr Touch have you fitted? there is a Model 1 (suitable for caravans up to 1200kgs), and a Model 3 - Heavy Duty (suitable for caravans up to 1500kgs).
My Pageant Bugundy is 1400kgs. Do you have any problems with ground clearance beneath the van? Does it affect the spare wheel carrier in any way?
Hi, there is a good letter in this months PC which has been submitted bya caravan service engineer with experience of movers. From what he says he has not had any problems jacking a wheel with correctly installed movers of any make. Perhaps your mover is not installed quite right.Have you ever had to jack up your wheel? If not...I would advise you to make sure that it will do so without problems before you set off again!
