Was it a purple colour? 😆I won't push my luck, but I have pm’d the OP.
If you have written evidence from them which verifies your complaint, there's no reason why they can't be named John.Because of forum rules, I will not name my last mover. Originally purchased at 1 year old and still under guarantee. The control unit packed up and it took much argument by myself and my dealer but their attitude was our products don’t fail. Eventually, they replaced it. This was an expensive so called, high-end product. In 2014, after my wheel detachment, a new mover was supplied. Insurance paid, £1200. This was fitted to a new van. It failed within months. At first, they insisted that the warranty was out of date as it would start from the original purchase date. More arguments. Next, my dealer refused to do the job as they would not deal with the company, so, I had to take it to the factory, at my expence. Two new actuators were needed.
Later the control unit failed again. A known fault which I had fixed on-line.
I wish I could warn people, but I understand the readons for the rules.
Nice to know, but I no longer have the info to back this up.If you have written evidence from them which verifies your complaint, there's no reason why they can't be named John.
Thanks for respecting our forum rules JohnNice to know, but I no longer have the info to back this up.
It’s always worth obtaining some quotations for fitting. But having to use an approved installer might limit it, but worth a punt.FINALLY! got caravan back, now need to order powrtouch evolution auto single axle. The going rate seems to be £1199 fitted by approved installer (a must for the proper warranty) . Is it worth hunting around for a better price for a "fitted at home" service, or are the prices locked down. I am happy yo pay the £1200, but would obviously prefer it to be less.
No one had any issues with Caravan Movers UK?
Ours was fitted by a tech appointed by Powertouch.FINALLY! got caravan back, now need to order powrtouch evolution auto single axle. The going rate seems to be £1199 fitted by approved installer (a must for the proper warranty) . Is it worth hunting around for a better price for a "fitted at home" service, or are the prices locked down. I am happy yo pay the £1200, but would obviously prefer it to be less.
Do you leave your motor mover engaged as that is not recommended by some manufacturers of motor movers.I fitted them myself after watch them fitted by The Caravan Nut.
View: https://youtu.be/_UMLLiuTHwE?si=eqK0e_8uepO1DkCN
I choose EMove EM303A Automatic (engage) version. Brand choice was because there was video showing me how to install them. Auto don't have a bar linking engagement mechanism but there is 4 more wires you need to run and connect. I think Auto is saver as it always engages at correct pressure once installed correctly, manual version relies on operater winding (use a drill) until indicator is at correct location. WARNING if not enough pressure is applied risk a run away caravan on slopes.
If installed by DIYer waranty is only good for 12mths and not transferrable.
I didn't shorten wires so can move them to another van which I'll be doing soon.
Mechanical installation is straight forward only took 1.5hrs, should be quicker 2nd time. Used simple scissor jack to lift them into place while fastening. Torque wrench is a MUST, don't guess it or you could have runaway caravan. What took most of time (few hrs) is cabling. Was impressed with kit that came with movers but you will need good crimpers for connectors. With currents involved can't afford a poor crimp. Instructions weren't great but video above filled in missing pieces.
The only negative to fitting MMs beside cost is 35kg payload penalty.
Positives are endless, park anywhere, push button levelling using ramp. Being able to do 180 for views or security. Lot harder to steal caravan that requires MM to move for hooking up.
Simply follow the advice provided by the manufacturer of the mover you have fitted. Failure to do so may invalidate any warranty offered by the maker.Do you leave your motor mover engaged as that is not recommended by some manufacturers of motor movers.
We would never leave our motor mover engaged.Simply follow the advice provided by the manufacturer of the mover you have fitted. Failure to do so may invalidate any warranty offered by the maker.
Likewise. Two reasons. One if it fails to retract when you want to tow you are in to a manual retraction session. Invariably it will be raining !Secondly it doesn’t do the tyres any favours.We would never leave our motor mover engaged.
Not sure of question?.Do you leave your motor mover engaged as that is not recommended by some manufacturers of motor movers.
I fail to understand how this is even possible. A couple of times I have inadvertently left the mover engaged. This is totally obvious before it it towed just a couple of feet. Yet I have read of people who have done this.Do you leave your motor mover engaged as that is not recommended by some manufacturers of motor movers.
That gave me the impression that you left the MM engaged to prevent theft, but it can be read two different ways? However if a toerag is stealing the caravan I don't think they will give a monkeys about it being difficult.Lot harder to steal caravan that requires MM to move for hooking up.
MMs should be disengaged when you've finished moving van ie only a few minutes. Also carry spare 9V battery. I've left remote turned ON couple times to find it flat next time. NB Auto can be disengaged manually if need be.
I was referring to when the caravan was in storage.I fail to understand how this is even possible. A couple of times I have inadvertently left the mover engaged. This is totally obvious before it it towed just a couple of feet. Yet I have read of people who have done this.
A friend of mine towed his van off site to be stopped at the exit and told the movers were engaged. Wheels were very hot after just a few hundred yards. Surely he must have felt it.
I have fitted a couple of movers in the past and they are easy for the practically minded. But you also need a decent degree of fitness. It has been a long time since I could scrabble under a van.Just to throw my two peneth in ... I bought a Leisurewize Emove EM203 motor mover from Halfords and although Halford's customer service was dreadful Leisurewize where fantastic. When we unpacked we had been sent to movers for the left wheel and not one for the right ... the personally drove out to replace it and brought some gifts for our van to apologise. Superb service.
I fitted it myself in little more than a few hours and it's great, easy to engage and works really well.
If you are on a budget and a bit handy the Emove is a no brainer from my experience
